Home > Wheels & Tyres > 22in wheels tyre pressures |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
mod edit, moved to the correct section ... - .- -.
29th Sep 2015 1:46pm |
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 |
sorry put it in the wrong section..thanks stan,fullfatrr sticker on rear window now too . 2009 Vogue SE Zermatt silver |
29th Sep 2015 1:51pm |
i'll let you off then ... - .- -.
29th Sep 2015 1:55pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I can't help you with exact pressures as I don't run those tyres, but from what I can suss most people with rubber bands tend to run them at higher pressure than standard, so 33 psi would be a good starting point
29th Sep 2015 6:04pm |
Thanks for you're help Martin. .I'll use your figures as a starting point and see how I get on..Thanks again. . 2009 Vogue SE Zermatt silver |
29th Sep 2015 11:38pm |
martin? ... - .- -.
30th Sep 2015 7:25am |
30th Sep 2015 8:10am |
don't know where i got the name Martin from. .. 2009 Vogue SE Zermatt silver |
30th Sep 2015 9:02am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
It's easy to determine the correct tyre pressure for any size tyre...
30th Sep 2015 9:16am |
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 |
I have 40 all round in mine 285 x 35 x 22, nice even wear all round |
6th Oct 2015 12:30pm |
Thanks for all the replies guys ..I,ll see how things go..very helpful . 2009 Vogue SE Zermatt silver |
6th Oct 2015 1:02pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I have those tyres on my 06 SC and run the pressures as per the label on the door pillar. I run at the lower pressures (sub 100mph unloaded) as that's how I drive and this seems fine. For a while I tried the higher over-100mph pressures and the ride over bumps was noticeably worse. |
10th Oct 2015 11:42am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Can any member with a 405 running on factory 22’s give some insight as to what they run their’s at? |
10th Oct 2015 12:37pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
My 2016 tyre pressures from factory are
10th Oct 2015 4:31pm |
