You can calculate the correct tyre pressures for a given tyre
Find the max load per tyre say 950kg for sake of argument (it's not but I can't be bothered to go and look.....)
950 x 4 = 3800kg max load
3800 / max gross weight say 3200kg = 1.1875
Find the max pressure of the Tyre on the tyre wall. Say 45psi....
45psi / 1.1875 = 37.89
So inflate to 38 psi.
All figures are made up so you need the proper numbers but you get the idea. There is nothing that can't be fixed with a hammer😜😜
