Home > Maintenance & Mods (L322) > brake pad warning light but cant find any faults
viper
I replaced front discs and pads a few thousand ago ( no warning lights at that stage ) and ive just had the BP warning light coming on /going off through a journey.
Appears to be one warning sensor per axle .
rear one appears to have been unplugged and taped up by a previous owner but for the purposes of elimination ive completely unplugged the cable for now from the box under the rear inner wing .
Ive also completely unplugged the front cable from the black junction box as well.
Ive still got the warning light so I'm assuming ive got a short further up the line somewhere? any ideas?
ive tried searching available topics on here but all are about changing the pads , which ive now eliminated
Post #350493 3rd Oct 2015 3:13pm
Brake Pad sensor works on a completed loop, if you've unplugged parts the loop is broken so you will need to wire the system so that it has a complete loop
Post #350494 3rd Oct 2015 3:23pm
viper
ah ok thanks , I thought the sensors was activated on a earth through the wire to the disc , if its a open circuit activation I will close both loops and I should be good, thanks
Post #350495 3rd Oct 2015 3:25pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
If it's anything like BMW.there is a resistor in the sensor and the ecu will only turn the light off if it sees a new sensor (different resistance) on the end of it,so a sensor change may be needed even if the pad wear has not got that low
But it may be different on a ff ,just a thought
Post #350498 3rd Oct 2015 4:02pm
viper
don't think its that Iron horse because I changed the front and kept the original sensor and I was ok for a few thousand , I'm sure its the back one that was disconnected and taped up, probably an open circuit under the tape
Post #350500 3rd Oct 2015 4:19pm
Just get a new sensor they are less than £20, and are plug and play. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #350510 3rd Oct 2015 5:42pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
When I replaced the rear pads the sensor was cracked at the elbow of the pad insert, I successfully broke it, and had a rear bad warning, bought a new rear lead from LR, fitted it and after a couple of minutes, the warning reset itself was @£20 for gen LR Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #350557 4th Oct 2015 6:29am
ironhorse
think beyond the box (its a rangerover)
Tha pad light comes on when the ecu thinks you need new pads not necessarily when they have worn out,depending on how hard you are on the breaks depends on if you beat the ecu thinking they are worn out
Post #350561 4th Oct 2015 7:20am
