Home > Technical (L322) > Welding exhaust in situ ... |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Disconnect the battery and leave for an hour before welding sir... Never had an issue and have welded countless 322’s sir |
2nd Oct 2015 9:52pm |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 |
Thank you kindly Craig.
2nd Oct 2015 9:57pm |
2nd Oct 2015 10:03pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
And try and get your earth clamp as close to where your welding, without getting in your way, as this also reduces the path that the current has to flow and reduces the risk of it frying any ECU's Yesterday I couldn't spell Engineer... Today I are one!
2nd Oct 2015 11:23pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
It's a good idea to earth both sides of the weld with a jump lead. That way the welder wont earth the other half of the weld through the Lambda sensors and ECU.
3rd Oct 2015 5:35am |
Are the pipes on the early cars stainless? I thought they were mild steel sir Im pretty sure they only went to stainless systems post 2009 models... |
3rd Oct 2015 8:33am |
Stainless steel is a pig to weld with a standard Mig welder, I would caution against it. When you see those wonderful shots of stainless being welded with a Mig and it looks sooooo smoooooth, it's a very expensive high frequency Mig welder that's being used, the same for ali
3rd Oct 2015 10:23am |
3rd Oct 2015 1:03pm |
Definitely stainless on my 2004 (2005MY) It's possible they changed to higher grade stainless for later ones, some of the lower grades of stainless will go brown (where road salt bakes onto them) and even develop a slightly rusty appearance when they get hot (like the cat/manifold end kind of hot), but that's as far as they go and don't rot like mild steel would. The higher grades discolour slightly with heat but still stay shiney. It's a little bit like how Bronze statues go dark brown then stay that way or centuries.
Yeah fair comment, and most of the Range Rover's exhaust is pretty well hidden anyway. I just happened to have some stainless wire when i did mine, came out ok, maybe i was just lucky. |
3rd Oct 2015 3:40pm |
Using stainless wire on mild steel and mild steel wire on stainless should have the same outcome, but I'm only guessing now. Using the wrong grade stainless wire on stainless steel is a disaster, as is using the wrong gas, it will cause porosity in the weld, and can also cause the weld to crack And then there's the staining that will also happen, dark brown / black mess that is a pita to shift. A pal of mine tried to weld some 304 with 316 wire and pure argon, didn't end well Unfortunately as stainless steel is an alloy unless you are 100% certain of the grade it's very hit and miss as to whether it will be a or ending.
3rd Oct 2015 6:16pm |
As i said, i was probably just lucky with mine.
3rd Oct 2015 7:07pm |
The trouble with alli is there is a fine line between weld and blob You've got to try and keep and amps down, the wire speed up and go like the clappers, otherwise it just burns back on one side and not join together, which results in a lot of and In fact if you do it right then you start high and slow to get it going then reduce the amps and increase the wire feed, can't do that on my Mig's, not even the BOC one
3rd Oct 2015 10:33pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Well mine defo isn't stainless, maybe someone fitted a later system to yours Zirconblue as I've not seen one on an early one yet...
3rd Oct 2015 10:55pm |
The hours wait is lunch time He didn't think to start earlier I would have thought that once the battery was disconnected everything was pretty much isolated, especially if you keep the weld area to a minimum ie, don't earth at the front bumper and start welding the rear
3rd Oct 2015 11:11pm |
