Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 |
First of all, I would like to thank all those who participated here, and not, thank you all for the big help, and most important the moral support, in my small odyssey.
24th Sep 2015 11:28pm |
as stubborn man I think solved freevel direction problem.now can rotate only clockwise.
25th Sep 2015 12:54am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Andrew, before you refit it this gearbox, i would wait for hopefully some advice from RRphil. even taking it to specialist, i would wait... it looks like the two teflon seal rings are damaged, you might want to find the debris... if they are not working, i dont think you would have any hydraulic pressure, this would mean TC is cycling fluid, against nothing..i cant think these were bad whilst box was in, it must have happened when you removed assemblies, (hammering?) for those F drum parts to weld together means something is very wrong, like spacers, or the bearing cups you show are wrong way round? etc. |
25th Sep 2015 6:44am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
It’s important that the PTFE rotary seals are held in place in their grooves with their scarf joint ‘closed’ (using petroleum jelly) to prevent the ends being caught as the oil pump assembly is lowered into place. As johnboyairey has already mentioned these seals direct the main cooling flow to the torque converter. If the seals fail then the flow direction to the TC will be reversed and the lock-up clutch will be applied.
25th Sep 2015 9:57am |
NO, I will not fit anything in this conditions, I have to replace both Teflon seals rings, that I can't have before 10/15 days, (can be found as generic part Phil do you know the size and dimensions)and of sure solve F brake problem, Because F clutch drum won't fit now.
25th Sep 2015 12:47pm |
with bmw part number , I will be able to order teflon rings from bmw dealer here, and so have rings in few days.
25th Sep 2015 1:52pm |
The same seal rings are used in the 5HP18, 6HP19 & 6HP26 transmissions as well as the 5HP24. BWM did sell them separately for the 5HP18 under their part number 24 23 1 422 210 (which superseded 24 23 1 421 112). I have no idea if they’re still available through BMW.
25th Sep 2015 6:49pm |
yes, right Phil, ,also my zf reference about piston ring say the same your
26th Sep 2015 6:14am |
I’m wondering if it might be best if I just send you a complete assembly
26th Sep 2015 5:16pm |
quick update:gearbox reassembled yesterday, and everything seems to be okay.
5th Oct 2015 12:49pm |
can anyone tell me which error code came out if oil level is low? |
5th Oct 2015 5:20pm |
If you are having a problem putting in TC bolts, make sure others are still loose, and file the first three threads to a taper, this will make the bolt go a bit further in, whilst locating the first hand turn...(straighter) and will be easier to then screw in. It happened to me also. When all four all the way in, -tighten etc.
5th Oct 2015 7:07pm |
yes John ,I always perform this procedure as described by you, but this time I had the head of a bolt get stuck somewhere, and could not turn the wheel, so I forced a little, and I think I slightly bent flexplate , and than t. converter slightly rattles in reverse.
6th Oct 2015 11:25am |
I have had a few odd noises since I did my gearbox, but they don't sound like your car. Mine sound like a rattle, and I think it's a stray piece of tinware, from the exhaust shields rattling, mine does it when reserving, or just idling forward. Only when driven from stone cold. I would not think its the TC though, as it goes the same way for forward and reverse. If you think you have damaged the flex plate, you might have a condition I had on a Mercedes I had. The crank position sensor takes a set routine of magnetic pulses, from the gaps in the flex plate, and this allows the sparking, and car to start. If one of the gaps is damaged, as mine was, from a broken off crank sensor, (previous owner snapped it and dropped it in). -it started, but it wouldn't Rev to max RPM. And car would not go faster than 80mph. (Misfire). Note on that car, (merc v6) you can't Rev it over 4000rpm, unless you are in gear, to stop it damaging engine by revving, say at traffic lights etc. You can check the state of the gaps, by very slowly rotating flex plate, with screwdriver in starter teeth, and looking through inspection holes.
6th Oct 2015 4:00pm |
