![]() | Home > Wheels & Tyres > Tyres, wheels, and spacers |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
What 20" wheels are you using??
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Standard LR wheels. http://www.fullfatrr.com/forum/topic32645.html
I'll refit the wheels later on today if possible. Might not be an issue.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Rear, always. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
^ curious, why? ... - .- -.
As Pete says, having better rear tyres favours understeer, which is easier to control. Taking it further, a rear tyre blowout is significantly more dangerous than front. I believe tests have shown improved water shedding too. |
Oversteer is much more fun though... |
Absolutely - when you're ready for it. |
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 ![]() ![]() ![]() |
front tyres do 80% of the hard work with turning and braking...Id rather stop than under steer |
Pretty sure stopping and turning were high on these guys' agendas... |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
The other thing to bear in mind is with that width of tyre and spacers you'll probably be rubbing what little sidewalls L322s have. Most ruts are made by narrower tracked vehicles, such as Defenders... Ed |
Ok I've fitted all 4 wheels and tyres now. They are standard LR wheels so offset should be correct.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I have also just fitted a set of new 285 50 20 tyres to a set of wheels, with the same offset as the RRS. I've got 9 inch with 45 offset. The tyres sit fat on the rims, (even though the rims are slightly wider than standard) with plenty of kerb dragging/bashing allowance, unlike the 255 50 20/standard rims' near vertical sidewall. Also the offset, pushes the faces out a bit too. Which fill the wheelarch space out. the overall height is about an inch higher than standard, so I expected an abnormal speedo reading, -but using an iphone app to gauge my speed, its somehow exactly correct, ie at 70mph, it reads 70mph on the app!
