Home > Technical (L322) > Charging Battery without removing everything |
HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244 |
Hi folks
27th Oct 2010 5:44pm |
In my opinion a battery operating correctly would not discharge even in the coldest weather. I leave mine outside all winter down to -10 with no problems starting even using the pre heat for 30 minutes!
27th Oct 2010 5:52pm |
The battery in mine is older. Car was built 2005.
1st Nov 2010 8:55pm |
Phil, you need something like the CTEK XS3600 battery conditioner which can be connected without disconnecting the battery. I have been using the CTEK for a number of years now on various Mercedes and the Range Rover and they are superb at keeping the battery in peak condition |
1st Nov 2010 9:12pm |
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 |
Phil,
1st Nov 2010 10:38pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Hi,
3rd Nov 2010 11:22pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35126 |
i think you might have been lucky doing that..the RR has many ecu's and they do take loads of power even when starting up every ecu gets checked with a burst of battery power....i messed with my drls and had to switch the ignition on/off quite a few times and the result was a flat battery ,so with winter coming i wisely invested in the new battery [only £117] ... - .- -.
4th Nov 2010 9:26am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1310 |
I've charged the battery whilst its been in situ loads of times ... there is normally enough space to get the charger into the engine bay, the bonnet closed to the first latch and then the car locked. When the car is awake it draws a lot of power, so best to lock it, let it sleep and let the charger do its business over a decent period of time.
4th Nov 2010 11:07pm |
