Home > Maintenance & Mods (L322) > DIY Umbrella Holder
Page 1 of 3 123>
DIY Umbrella Holder
Having been bemused by the price LR charge (£99) to hold an umbrella in place on the underside of the rear loadspace cover I thought I'd have a go myself. This is my solution for anyone that may chose to have a go.
Materials,
Two elasticated Velcro straps 300mm long
Two 50mm aluminium discs
Four 12mm long self tapping screws
Bottle of Superglue
I chose to polish the exposed side of each aluminium disc and drilled two 5mm dia holes in each 10mm from the edge.
I shortened each of the Velcro straps to an overall length of 200mm including the buckle using Superglue instead of stitching to form the return over the buckle.
Be very careful if you chose to do this to get the Velcro straps the correct way round.
I positioned each of the Velcro straps on the rear of the aluminium discs with 40mm of strap/buckle protruding to one side and glued in place.
Again be careful to get the Velcro straps the correct way round.
You should end up with this.
I measured the thickness of the rear loadspace cover which is 14mm thick and chose 12mm self tapping screws to fix the discs/straps in place.
I determined the position the position of each disc on the underside of the loadspace cover and lightly marked the screw holes with a bradle. I then put a blob of Superglue in the rear centre of each disc and the corresponding positions on the parcel shelf and screwed each disc/strap into place. Be very careful tightening the screws, the panel they are screwing into is fairly soft hence the Superglue to additionally hold the discs/straps in place.
You should end up with this,
With the umbrella in place,
That's it Thumbs Up With a saving of approx £95 on LR's price. Very Happy
Discs from,
http://www.ebay.co.uk/itm/400823467840?_tr...EBIDX%3AIT
Straps from,
http://www.amazon.co.uk/gp/product/B00JORP...ge_o00_s00
Post #345455 1st Sep 2015 11:10am
Bow down Bow down Bow down Proper job Thumbs Up
Post #345458 1st Sep 2015 11:20am
johnboyairey
not that have needed an umbrella (or two!) this month though eh?
in fact you could say it's not a 'nicedayforit!'
nice simple job though.
Post #345459 1st Sep 2015 11:24am
entered in the wiki Dave. Thumbs Up ... - .- -.
Post #345461 1st Sep 2015 11:25am
^ Ta. Thumbs Up
Post #345462 1st Sep 2015 11:26am
steptoe
Section of polyplumb pipe laid in the angle of the boot held in place with velcro. In fact cut the one section in half and you've two sections of pipe, cable tie together and storage for two umbrellas. Thumbs Up
http://www.wickes.co.uk/Wickes-Polyplumb-B...m/p/424993
Post #345474 1st Sep 2015 12:07pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
isn't it ironic how you will get soaked running from the door to the trunk to get the umbrella Laughing 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #345486 1st Sep 2015 1:44pm
http://www.fullfatrr.com/forum/topic32627.html Cool Whistle Thumbs Up
Post #345488 1st Sep 2015 1:52pm
Zirconblue
the Jaguar umbrella holder strap kit is only about £23 from main dealers. Part number C2C5101.
I'm not saying it's better than your home made kit, but for someone who doesn't want to spend the time making one.
Post #345511 1st Sep 2015 5:10pm
Personally, I'd rather use velcro than a buckle - something like this would be perfect -
http://www.ebay.co.uk/itm/VELCRO-Reusable-...2349d54d48
I use it all the time, one side sticks to the other - you just cut it to the length you want - it doesn't fray - fantastic stuff Thumbs Up
Post #345523 1st Sep 2015 5:39pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Please stop putting these ideas in my head. Big Cry
now I'm looking into a brolley holder Laughing Laughing Laughing
nice job ndf. Thumbs Up
Post #345546 1st Sep 2015 7:41pm
Zirconblue
and if you wanted leather straps, a couple of nato pattern watch straps would do the job. Wink
Post #345554 1st Sep 2015 8:18pm
perfectly simple yet so effective.... Looks great. Thumbs Up Previously..
Post #345567 1st Sep 2015 9:21pm
i've had more thoughts on this and methinks this could be mounted just under the rear seats instead of the parcel shelf... ... - .- -.
Post #345623 2nd Sep 2015 10:08am
^^ I think you're right - I just checked and atlas in the L405 there is an almost perfect little shelf that would take 2 umbrellas in opposite directions -
The rear seats don't tumble over in the L405 so they can stay there - that would be the only concern in an L322
Post #345627 2nd Sep 2015 10:34am
Page 1 of 3 123>
