Home > Technical (L322) > Heated seat. |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 118 |
Hi Folks.
22nd Aug 2015 9:39am |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
Maybe the fuse. I'm sure the switch and lights come on if the fuse is blown.
22nd Aug 2015 9:41am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Had the same symptoms on my X-Type, it was the heater elements in the seat had packed up. |
22nd Aug 2015 10:03am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Does it cool ? 2008 MY Supercharged
22nd Aug 2015 11:49am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
As said above, folks need to know if its JUST heated or heated & cooled... Different issues with different fixes! |
22nd Aug 2015 6:06pm |
Sorry folks for taking so long.
24th Aug 2015 3:24pm |
Sound like the temperature sensor is fubared , on cooling its a closed loop so the temperature sensor is missed out .
25th Aug 2015 2:00am |
Had it to the local Indi today and it's
27th Aug 2015 6:23pm |
Same motor runs the cooling and heating it's just the way the current flows across the cell affects the temperature so they must be saying it's easier to replace everything , I would have the plastic ducting changed as well if it doesn't come as part of the motor because it tends to split with time . 2008 MY Supercharged
28th Aug 2015 12:36am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Be interested to know how you get on, cost ETC as have the same issue with my passenger seat. Wife will want a warm rear come winter |
30th Aug 2015 10:59pm |
