Home > Technical (L322) > Heated seat.
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Heated seat.
Hi Folks.
My heated seat on the drivers side has stopped working?
The lights on the dash come on and stop on but no heat
Comes from the seat.
Any ideas?
Gary
Post #343731 22nd Aug 2015 9:39am
IanT599
Maybe the fuse. I'm sure the switch and lights come on if the fuse is blown.
Unsure as to its location.
Post #343732 22nd Aug 2015 9:41am
Zirconblue
Had the same symptoms on my X-Type, it was the heater elements in the seat had packed up.
Post #343744 22nd Aug 2015 10:03am
Does it cool ? 2008 MY Supercharged
Post #343762 22nd Aug 2015 11:49am
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
If they are heat/cool it will most likely be the ntp sensor in the peltier cooler heater unit.
Whole lot job i believe, very expensive for what it is and a Censored to change.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #343781 22nd Aug 2015 1:26pm
As said above, folks need to know if its JUST heated or heated & cooled... Different issues with different fixes! Thumbs Up
Post #343821 22nd Aug 2015 6:06pm
Garyfax
Sorry folks for taking so long.
Yes the cooling side works 100% fine
Post #344159 24th Aug 2015 3:24pm
Sound like the temperature sensor is fubared , on cooling its a closed loop so the temperature sensor is missed out .
I have the same problem and would love to know a cheaper answer other than completely new Peltier cells . 2008 MY Supercharged
Post #344254 25th Aug 2015 2:00am
Garyfax
Had it to the local Indi today and it's
the seat heater motors that's the problem,
Hopefully get sorted next week.
Post #344799 27th Aug 2015 6:23pm
Same motor runs the cooling and heating it's just the way the current flows across the cell affects the temperature so they must be saying it's easier to replace everything , I would have the plastic ducting changed as well if it doesn't come as part of the motor because it tends to split with time . 2008 MY Supercharged
Post #344818 28th Aug 2015 12:36am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Be interested to know how you get on, cost ETC as have the same issue with my passenger seat. Wife will want a warm rear come winter Laughing
Post #345202 30th Aug 2015 10:59pm
