![]() | Home > Technical (L322) > After market air suspension compressor |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Can't see why it won't work, you will need to split the original and just change the compressor, there are two exhaust valves and a temp sensor, the temp sensor is removable from the old pump, I'd fix it to the new pump somehow and isolate the two exhaust valves... these will all have to be connected or the EAS ECU won't like it and will throw faults...
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
I second the piston and ring replacement.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3660 ![]() ![]() |
You do realise that the EAS system runs at nearly 200 psi, not sure how a tyre pump would fair running at that load or temp.
$678 here in Sydney $25 to get it up to Banana land. |
marshy Member Since: 20 May 2014 Location: ipswich Posts: 34 ![]() ![]() ![]() |
That price is good |
Last year I gave the car a Christmas present of a new EAS pump, it set me back £299, that's $639, so your price is not that outrageous. Just had a look on fleabay and they seam to be around £289 ($618), so your still not that far off your price with the carriage, and it's already a month nearer to you! Yesterday I couldn't spell Engineer... Today I are one!
www.karcraft.com.au Great bunch of guys, they are a major importer, ask them to email you their price list. |
