Home > Technical (L322) > After market air suspension compressor
marshy
Australia 2002 Range Rover HSE 4.4 V8 Buckingham Blue
Hi all I need advice on the air suspension compressor. My factory one has just about died and I am thinking of putting in a aftermarket one. Eg TJM, ARB. now I can't see why it cannot work as it would be just wired into the old wiring so that everything still work when I wanted it to. Has anyone done this to there's???. A replacement here in Australia will cost me around $700aus. or a aftermarket one for say 300 plus a little more for it to be wired in by a person. Please throw me some thoughts good or bad.
cheers 02 l322 4.4 HSE
Sitting on 20's
All in Buckingham blue
Post #343269 19th Aug 2015 11:01am
Can't see why it won't work, you will need to split the original and just change the compressor, there are two exhaust valves and a temp sensor, the temp sensor is removable from the old pump, I'd fix it to the new pump somehow and isolate the two exhaust valves... these will all have to be connected or the EAS ECU won't like it and will throw faults...
Will just take some playing with...
Have you tried a new piston ring on your old compressor, it's usually them that go, the motors tend to be OK... if it's just putting out a low amount of air then this usually works... Some on ebay... Pete
Post #343277 19th Aug 2015 12:45pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
I second the piston and ring replacement.
If you put an ARB TJM its going to be super noisey, and I dont think these will last long anyway.
Post #343319 19th Aug 2015 4:14pm
miggit
You do realise that the EAS system runs at nearly 200 psi, not sure how a tyre pump would fair running at that load or temp.
If you strip the pump and the liner in the cylinder is not scored then a new piston ring will sort it out. However, if the pump has stopped all together, the chances are that the liner is fubar'd. I realise that your on the other side of the world and carriage is an issue, but, there was a mob in Germany, selling a new cylinder and piston kit on fleabay. It might have been advertised for the Audi, but when you get down to the guts they are pretty much the same, they are all Wabco, and I'm sure that they could help. Cos if you ain't paying to ship the motor you save yourself heaps Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #343523 20th Aug 2015 10:25pm
RR P38
$678 here in Sydney $25 to get it up to Banana land.
Post #343531 21st Aug 2015 2:06am
marshy
That price is good Very Happy where is that from may need to look at that if a compressor mob carnt fix it. 02 l322 4.4 HSE
Sitting on 20's
Post #343536 21st Aug 2015 4:45am
miggit
Last year I gave the car a Christmas present of a new EAS pump, it set me back £299, that's $639, so your price is not that outrageous. Just had a look on fleabay and they seam to be around £289 ($618), so your still not that far off your price with the carriage, and it's already a month nearer to you! Yesterday I couldn't spell Engineer... Today I are one!
Post #343615 21st Aug 2015 12:34pm
RR P38
www.karcraft.com.au
Great bunch of guys, they are a major importer, ask them to email you their price list.
Post #343628 21st Aug 2015 1:41pm
