Home > Maintenance & Mods (L322) > Viscous fan conversion
Page 3 of 3 <123
No he didn't he got an adjustable one for £12.95
Half way down the page http://www.bbclassics.co.uk/electrical-accessories.html[/quote]
I think they sell those on eBay though if you want one... I still say you really need an adjustable one... every engine likes to run at different temps.... they never seem to be "just" right.... Pete
Post #343500 20th Aug 2015 7:39pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
"Does anyone know the safe operating range of a TD6?"
Monitored our motor on the motorway and town driving last week, as well as checking auto box oil temp.
Motorway at a steady 70mph ish was 87 degrees. Climbed no higher than 91 degrees on the back B roads pushing it as I was in a hurry.
Monitored with my IID tool and 'phone sat in front of the sat nav.
The TD6 runs miles cooler than the 4.4. One I checked on a test run recently never dropped below 92, It would average around 98 and at times went to 105 degrees. A bit too hot for my liking, but they are designed that way.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #343501 20th Aug 2015 7:46pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
pete
looks like it is adjustable mate (got a little trimmer inside for adjustment)
never had much joy with the ones you stick up the rad hose even with the rubber nodder fitted
so just looking at an alternative
cheers nige
Post #343510 20th Aug 2015 9:13pm
miggit
This is about the cheapest electronic unit that I found, but I would recommend doing a search as you may find one cheaper Thumbs Up
https://www.merlinmotorsport.co.uk/p/elect...itment-efc Yesterday I couldn't spell Engineer... Today I are one!
Post #343515 20th Aug 2015 9:57pm
Used them on loads of cars, never had one leak, two jubilee clips, that are the correct size, side by side and a smear of non setting instant gasket or silicon and Roberts your Mothers Brother.... Thumbs Up
If that one is adjustable then great... mine is a Kenlow because it came off another car and I had it in stock but usually I just get the cheapest, they are very reliable, never had one fail yet.... Pete
Post #343517 20th Aug 2015 10:03pm
miggit
Shocked Shocked I thought that you preached the use of a kenlowe condom, to avoid any little spills and mishaps that can result, Pete, I'm shocked, I didn't have you down as a quick smear in the back of the shed, type of guy Shocked Shocked
And the Revotec is adjustable, but how accurate that tiny little pot is, is anybody's guess. Yesterday I couldn't spell Engineer... Today I are one!
Post #343522 20th Aug 2015 10:14pm
miggit
ironhorse, just stumbled on this Thumbs Up
http://www.ebay.co.uk/itm/Revotec-Electron...1a02e9f398 Yesterday I couldn't spell Engineer... Today I are one!
Post #343526 20th Aug 2015 10:37pm
ironhorse
That's the one miggit,nice one cheers
Post #343543 21st Aug 2015 7:33am
How much.... Shocked Shocked Shocked Shocked Shocked Pete
Post #343571 21st Aug 2015 9:47am
ironhorse
half a tank of fuel pete Thumbs Up lol
Post #343586 21st Aug 2015 10:26am
miggit
It is a wee bit expensive, and like ironhorse, I am not totally convinced that the slip it down the side of the hose and hope method is the best. However, unlike ironhorse, I am prepared to give the "back shed engineering" solution a try as it's about a third of the price, and if it was a total waist of time the internet would be full of moans! Yesterday I couldn't spell Engineer... Today I are one!
Post #343601 21st Aug 2015 12:00pm
Kenlowe has been around for longer than me and it's worked fine for generations of petrol heads...
As with most of these things it's down to how you do it, faults and failures are usually down to poor fitting.... Thumbs Up
When I moved to Yorkshire years ago the "tight yorkshire man" rubbed off on me... Rolling with laughter
Ironhorse... thats 1 1/2 tankfulls of LPG for me.... Shocked Shocked Thumbs Up Thumbs Up Pete
Post #343630 21st Aug 2015 1:47pm
yorkie3259
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Hi Folks
Out of interest has anyone else fitted a Kenlowe fan. I've had one fitted since 2012 and it works fine only problem is I fitted it with cable ties through the radiator which works fine except when I have to take it off, means removing bumper, ac fan etc to get the the ties. Just wondering if anyone has a better solution for mounting them. Thinking about mounting it on to the old plastic cover just not sure it'll be strong enough?? Do I really have time to tinker with one of these
Post #467002 2nd Feb 2018 6:26pm
Page 3 of 3 <123
