Home > Maintenance & Mods (L322) > EPB clean up
RRSHSEDL
United Kingdom 2007 Range Rover HSE Td6 Stornoway Grey
EPB clean up
I was about to go through the process of changing rear pads and decided to check out the EPB shoes. Someone has posted a step by step guide that I thought I should be able to follow, but hit trouble in that I was trying to rotate the rear disc to locate the back off screw inside brake disc, but my wheel will only move a few inches and does not rotate all way round to match up with the hole. I only have one wheel jacked up at this point. What is sopping my wheel from spinning 360 degrees?
Post #342800 16th Aug 2015 6:41pm
question, do you have a sport? ... - .- -.
Post #342801 16th Aug 2015 6:46pm
I should think likely from his username, however in response, what is stopping you rotating it is the fact that you only have one of the wheels off the ground, the diff will want to rotate the opposite wheel counter clockwise, as this is locked by being on the ground, then you are then trying to put the turning motion up the propshaft into the centre diff. Lift the other back wheel too and you should be golden Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #342805 16th Aug 2015 7:01pm
RRSHSEDL
Will try tomorrow. I was hoping it was something I was doing wrong in the process. Thanks for the quick reply
Post #342813 16th Aug 2015 7:23pm
thanks for answering my question Evil or Very Mad ... - .- -.
Post #342814 16th Aug 2015 7:25pm
RRSHSEDL
haha sorry thought it was obvious from my username Laughing if you have anymore to add i am all ears
Post #342820 16th Aug 2015 7:30pm
then maybe you should enrol on our sister forum dedicated to sports.
http://www.rrsport.co.uk/ ... - .- -.
Post #342833 16th Aug 2015 8:41pm
Rolling Eyes Whistle Rolling Eyes
Post #342854 16th Aug 2015 9:15pm
RRSHSEDL
Thanks for your info as now removed both rear pads/discs replaced all works a treat no more squealing from EPB... now onto next job on the list Very Happy
Post #343874 22nd Aug 2015 11:47pm
