Home > Maintenance & Mods (L322) > EPB clean up |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
question, do you have a sport? ... - .- -.
16th Aug 2015 6:46pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8659 |
I should think likely from his username, however in response, what is stopping you rotating it is the fact that you only have one of the wheels off the ground, the diff will want to rotate the opposite wheel counter clockwise, as this is locked by being on the ground, then you are then trying to put the turning motion up the propshaft into the centre diff. Lift the other back wheel too and you should be golden There is nothing that can't be fixed with a hammer😜😜
16th Aug 2015 7:01pm |
RRSHSEDL Member Since: 15 Aug 2015 Location: Scotland Posts: 11 |
Will try tomorrow. I was hoping it was something I was doing wrong in the process. Thanks for the quick reply |
16th Aug 2015 7:23pm |
thanks for answering my question ... - .- -.
16th Aug 2015 7:25pm |
haha sorry thought it was obvious from my username if you have anymore to add i am all ears |
16th Aug 2015 7:30pm |
then maybe you should enrol on our sister forum dedicated to sports.
16th Aug 2015 8:41pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
16th Aug 2015 9:15pm |
Thanks for your info as now removed both rear pads/discs replaced all works a treat no more squealing from EPB... now onto next job on the list |
22nd Aug 2015 11:47pm |
