Home > Technical (L322) > Back to the problematic rear door module, help please |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Doesn't the one touch have to have the position re-learned?
9th Aug 2015 9:22am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3141 |
I think The wire for the anti-trap/release is somehow connected to the one touch facility? I have just replaced the regulator in my rear dvr side door and the one touch only worked when I had re plugged the aforementioned wire in. It hangs down in the leading edge of the door and plugs into a tiny flat spade socket in The wire loom below - I would make sure it hasn't separated.
9th Aug 2015 11:40am |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
Thanks guys, but already tried the learn function, all other windows done, like i say, if i put the other module in, it works one touch up.
9th Aug 2015 12:46pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Have you tried the new module in the other door...??? Pete
9th Aug 2015 1:20pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
IID tool has a setting for one touch on or off, maybe the module default is off and needs to be turned on? |
9th Aug 2015 3:27pm |
Ill plug in the iid and have a look.
9th Aug 2015 3:44pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I've got a similar problem, the "one touch" up or down does not work on the rear door drivers side. I only really noticed it when I tried to use the "lazy unlocking" feature which is supposed to open all the windows and the sunroof - sunroof didn't budge at all (works normally otherwise) and the rear door window won't close or open fully without repeated actuation via the switch.
9th Aug 2015 6:09pm |
Iid says one touch enable disable. Nothing else. So, who knows.
10th Aug 2015 9:52am |
disable then re-enable? |
10th Aug 2015 10:14am |
I can't find this in the IIDTool menu can someone point me in the right direction. I have disabled and then enabled the windows dosing/opening from the remote. This didn't make any difference but I'd be keen to try the disable/enable of the one touch closing but can't find it. Also what's the procedure to teach the windows what they need to know to work properly. Geoff |
10th Aug 2015 10:58am |
