![]() | Home > Technical (L322) > Back to the problematic rear door module, help please |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Doesn't the one touch have to have the position re-learned?
I think The wire for the anti-trap/release is somehow connected to the one touch facility? I have just replaced the regulator in my rear dvr side door and the one touch only worked when I had re plugged the aforementioned wire in. It hangs down in the leading edge of the door and plugs into a tiny flat spade socket in The wire loom below - I would make sure it hasn't separated.
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Thanks guys, but already tried the learn function, all other windows done, like i say, if i put the other module in, it works one touch up.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Have you tried the new module in the other door...??? Pete
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
IID tool has a setting for one touch on or off, maybe the module default is off and needs to be turned on? |
Ill plug in the iid and have a look.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
I've got a similar problem, the "one touch" up or down does not work on the rear door drivers side. I only really noticed it when I tried to use the "lazy unlocking" feature which is supposed to open all the windows and the sunroof - sunroof didn't budge at all (works normally otherwise) and the rear door window won't close or open fully without repeated actuation via the switch.
Iid says one touch enable disable. Nothing else. So, who knows.
disable then re-enable? |
I can't find this in the IIDTool menu can someone point me in the right direction. I have disabled and then enabled the windows dosing/opening from the remote. This didn't make any difference but I'd be keen to try the disable/enable of the one touch closing but can't find it. Also what's the procedure to teach the windows what they need to know to work properly. Geoff |
