Home > Technical (L322) > 4.4 tdv8 brakes
4.4 tdv8 brakes
I seem to have a small problem with the brakes on mine.
No binding, have checked this out, but i do seem to require more pedal force to get the same result as the 3.6, its only marginal but i have noticed it.
I have had the recall done, the pedal isn't spongy just seems to require more braking effort. I am going to change the pads and discs to see if it makes any difference, and for piece of mind.
Any one else noticed this or are they pin sharp like a good set of 6 pot callipers should be? There is nothing that can't be fixed with a hammer😜😜
Post #340648 3rd Aug 2015 8:28pm
They should be pin sharp! I drive them often, all different ones and they usually feel more positive than 4 pots!
Post #340653 3rd Aug 2015 8:38pm
Will be new discs and pads then!
Probably down to contamination again like the last set on the 3.6, will have a look when I take them apart. Is there a torque setting for the caliper bolts. I'm assuming it's low as they are alloy? There is nothing that can't be fixed with a hammer😜😜
Post #340753 4th Aug 2015 4:31pm
well they have changed the design of the calipers so the bolts don't bolt straight to the calipers any more, they bolt to an steel insert on the calipers, so they are now Censored tight...... and require what looked like a special socket, but was actually a standard non Hex socket! but fundamentally the same procedure as the 3.6 Thumbs Up
Thanks to Dan for a very good Price, but I ended up shouting at the supplying main dealer as they were in a pretty bad state, they gave me an extra special price on the parts. There is nothing that can't be fixed with a hammer😜😜
Post #341186 7th Aug 2015 4:05pm
g1968g
Hi
I have a 2010 5.0 SC and I think the same. It's just been into JLR where new pads were fitted all round. The hose mod was also done. Now I have it back, I don't think it's much better.
My last car was a 2006 TDV8 (3.6), that was much better.
cheers
Geoff Looking for FFRR
Post #341206 7th Aug 2015 7:19pm
Much better after swapping the discs and pads at the front! There is nothing that can't be fixed with a hammer😜😜
Post #341326 8th Aug 2015 8:55pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
I need to do the front discs and pads on my 4.4 TDV8. Is there anything that's going to stump me compared to my old TD6 ?? Any help appreciated. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #398720 1st Aug 2016 7:18pm
No, it should be fairly straight forwards.
Have a look on the wiki, it's the same process as the 4 pots on the 3.6👍 There is nothing that can't be fixed with a hammer😜😜
Post #398735 1st Aug 2016 8:24pm
Mactech
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Not really!
Just check out my comments on this thread:
http://www.fullfatrr.com/forum/topic37454.html
A good 5mm punch is required to get the pad retaining pins out! 2012MY Range Rover 4.4 TDV8 Vogue...now gone!
2007MY Mercedes C200 Estate 'Albert'
1997MY Defender 90 TDI 'Vera'
Post #398736 1st Aug 2016 8:25pm
666tur
Thanks. Dealer wants £680 front discs and pads!! 2012 4.4TDV8 VSE
Post #398737 1st Aug 2016 8:26pm
666tur
PS will a normal caliper piston spreader deal with the six pots??never tackled a brembo caliper. Have them on my Porsche and not needed to do them yet. 2012 4.4TDV8 VSE
Post #398742 1st Aug 2016 8:34pm
No.
I did it with the pads and a pair of grips
Do it before you remove the caliper to replace the disc.
Squeeze the pads against the caliper with a pair of big grips. Squeeze and replace the pad on one side at a time so the Pistons in the other side don't pop out, putting in the new pads as packers before you swap the disc.
Then take out the new pads remove the caliper and disc. Then when refitting you should have the caliper retracted enough. There is nothing that can't be fixed with a hammer😜😜
Post #398794 2nd Aug 2016 8:48am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I've noticed the same on my 4.4 TDV8 and without point of reference (this is my first FF), I have been putting it down to the weight of the vehicle etc. Although they stop well enough, they don't have as much initial bite as I expected from six-pot brakes...discs and pads are in good fettle.
Post #398806 2nd Aug 2016 9:54am
mzplcg
Yeah, my Supercharged is like that too, almost as if the servo is not rated highly enough. However, give them a mighty stomp and the car stops on a sixpence.
Post #398811 2nd Aug 2016 10:41am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Im chuffed to bits with these calipers and discs Craig fitted to this one before i brought it and im glad i never brought any other one as the few ive driven dont come close to power or quietness for a diesel Bow down there the best ive ever driven and used on a range i use greenstuff pads and stops better than a pals sports car Smile Thumbs Up Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #398846 2nd Aug 2016 3:53pm
