Home > Technical (L322) > Lower tailgate rattle
dogsbody21g
United Kingdom 2009 Range Rover Vogue SE TDV8 Rimini Red
I have isolated an irritating rattle from the left rear of my 2009 Vogue to the lower tailgate by wedging that with a small piece of rubber which cures the problem. Presumably some adjustment to the latch is required. Any advice prior to attempting that would be appreciated.
Post #340413 2nd Aug 2015 12:50pm
You need to slacken off the locking pin bolts on the bodywork and probably move the locking pin slightly to the rear of the car and try locking it again. I had the same as you and found the locking pin was too far forward and the lock simply didn't latch over it. Moving it to the rear allowed the lock to latch.
Conversely if the lock is definitely latching over the pin you need to move the locking pin slightly forwards to tighten things up a bit to stop the tailgate rattling.
It's one or the other. Very Happy
And welcome to the Forum Thumbs Up
Post #340429 2nd Aug 2015 2:27pm
trail and error...undo the screws and adjust for non rattle mode... ... - .- -.
Post #340430 2nd Aug 2015 2:28pm
dogsbody21g
Thanks for the advice - all sorted now!
Post #340443 2nd Aug 2015 4:58pm
Post #340445 2nd Aug 2015 5:32pm
Thumbs Up Bow down Thumbs Up
Post #340482 3rd Aug 2015 1:00am
Zirconblue
Is it actually latched on both sides?
Sometimes with mine if I dont hold it in the middle to close it one side won't latch
Post #340487 3rd Aug 2015 2:00am
