![]() | Home > Technical (L322) > Lower tailgate rattle |
You need to slacken off the locking pin bolts on the bodywork and probably move the locking pin slightly to the rear of the car and try locking it again. I had the same as you and found the locking pin was too far forward and the lock simply didn't latch over it. Moving it to the rear allowed the lock to latch.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
trail and error...undo the screws and adjust for non rattle mode... ... - .- -.
dogsbody21g Member Since: 20 Aug 2014 Location: Devon Posts: 10 ![]() ![]() ![]() |
Thanks for the advice - all sorted now! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Is it actually latched on both sides?
