![]() | Home > Maintenance & Mods (L322) > Viscous fan conversion |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
Just under halfway down this page.... Jaguar X type fit very well
djharm Member Since: 28 Dec 2012 Location: breda Posts: 78 ![]() ![]() ![]() |
This guy is selling six...
It is advertised as ajustable from 70 to 120 degrees Celcius.
The one I got came with a soft start relay, otherwise use an 80amp relay, direct fused supply from the battery and an ignition switched supply for the control feed...
Thanks. cars on the side;
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
The fan control module on the X-Type is fixed to the fan housing if i remember correctly. |
Looking at the wiring diagram, I was wondering what battery input 2 and 3 are. one from the thermostat and one from the car ignition I assume.
Wht/Grn to feed from controller
While gathering parts, I removed my viscous fan. I now see a significan drop in temperature on the highway. Looks like a broken egr thermostat. Had this problem before so I replaced it about 6 months ago. Maybe it took a beat while removing the viscous fan. Or am I missing something? cars on the side;
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Pete, Buddy got to ask, have you got a fan kill switch? Only ask as it was a must add on for Jeeps with an electric fan conversion to stop them coming on when swimming, and drowning the engine. Yesterday I couldn't spell Engineer... Today I are one!
Oh yes, wired into a very annoying buzzer so you don't forget to turn them back on when out of the water.... Pete
Is that like those alarms that you hear on the war films just before the submarine dives |
I changed mine because the viscous fan was not working and it was cheaper than a new one of them, it's also handy when wading but modern fans blades don't tend to break when they hit water and the engine is pretty water friendly as well...
