Home > Technical (L322) > Help please - water in oil
Roystonh
Hi
I can't find my handbook but I have a warning light "water in oil check handbook"
I have a 2011 4.4 TDV8 and it went to the dealer for a few bodywork jobs including the brake recall. I drove home fine but within a short distance to the house this warning appeared.
I have let the car cool and restarted - the light is still there. Should I call LR assist or see what happens? I haven't filled up with fuel for a while and it was fine before.
Thanks Roy 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #338903 24th Jul 2015 7:18pm
Call LR... water in oil is not good and has nothing to do with putting fuel in it.... Pete
Post #338917 24th Jul 2015 8:20pm
Roystonh
Thanks Pete - bit of a pain really as it's been away for a fortnight already - will call them in the morning hopefully it will be covered by warranty
Cheers Roy 2005 L322 Vogue Gold gone
Post #338928 24th Jul 2015 8:54pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I knew there was a water sensor in the fuel circuit but not in the oil?
Post #338960 24th Jul 2015 11:45pm
It will be water in your fuel not oil , I don't know if you have a fuel separator to drain it off but I guess there is one somewhere. I would be tempted to treet your tank to some Fuel Set because it sounds like you have crap diesel from your last fill up ! 2008 MY Supercharged
Post #338964 25th Jul 2015 1:42am
ebajema
Either that or (like my poor mum) the tank cap wasn't on properly and rain water made it into the tank !!! My dad spent hours getting it all out of the tank Sad.
Another problem could be (but highly unlikely IMHO) is water/coolant in the engine oil. However, I'm not aware of a sensor in the oil to detect water. On my 4.2 both heat exchangers blew (first coolant into the ATF and a month later coolant into the engine oil and vice versa (oil in coolant)). This was a known issue on the 2006 heat exchangers not only in FFRRs but also in other cars with the ZF 6 speed (found it on an Australian forum on the ZF). Anyway, I don't think it is this issue but just in case you do find water in the engine oil or ATF, this could be the cause (even though those heat exchangers should be much better since 2006/2007 one should think............). MY 2010 5.0 SC Galway green and sand interior!!
Post #338971 25th Jul 2015 3:47am
Sounds like water in the diesel, can't even find the warning light description for that in the manual. On the hilux we have there is a drain at the bottom of the fuel filter, to remove the water. It may be the same on the ffrr. Chances are it will need resetting by the dealer or Iid tool. There is nothing that can't be fixed with a hammer😜😜
Post #338976 25th Jul 2015 7:25am
Water in fuel is a big problem on boats ( DUH ) and we have sworn by this stuff for years , can't do any harm and potentialy do a lot of good .
http://liquideng.co.uk/collections/fuel-set-collection 2008 MY Supercharged
Post #339021 25th Jul 2015 11:43am
