Home > Technical (L322) > Help please - water in oil |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
Call LR... water in oil is not good and has nothing to do with putting fuel in it.... Pete
24th Jul 2015 8:20pm |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 |
Thanks Pete - bit of a pain really as it's been away for a fortnight already - will call them in the morning hopefully it will be covered by warranty
24th Jul 2015 8:54pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I knew there was a water sensor in the fuel circuit but not in the oil? |
24th Jul 2015 11:45pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
It will be water in your fuel not oil , I don't know if you have a fuel separator to drain it off but I guess there is one somewhere. I would be tempted to treet your tank to some Fuel Set because it sounds like you have crap diesel from your last fill up ! 2008 MY Supercharged
25th Jul 2015 1:42am |
Either that or (like my poor mum) the tank cap wasn't on properly and rain water made it into the tank !!! My dad spent hours getting it all out of the tank .
25th Jul 2015 3:47am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8515 |
Sounds like water in the diesel, can't even find the warning light description for that in the manual. On the hilux we have there is a drain at the bottom of the fuel filter, to remove the water. It may be the same on the ffrr. Chances are it will need resetting by the dealer or Iid tool. There is nothing that can't be fixed with a hammer😜😜
25th Jul 2015 7:25am |
Water in fuel is a big problem on boats ( DUH ) and we have sworn by this stuff for years , can't do any harm and potentialy do a lot of good .
25th Jul 2015 11:43am |
