![]() | Home > Technical (L322) > 6hp26 transmission failure on MY08 tdv8 |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Sorry to hear that.
Previously-enjoyed DD295 transfer cases are relatively plentiful here in the UK because the same case is used in the Disco 3, Disco 4 and the RR Sport but I don�t know how easy they are to come by in Oz? Having said that, if the parts are available then an input shaft swap ain�t difficult either
And in case you fancy having a go yourself : http://www.fullfatrr.com/forum/topic14798.html http://www.fullfatrr.com/forum/topic12404.html Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
thanks Phil for the prompt reply. An option nearby is a wrecked 10MY facelift L322.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
just trying to figure out what has happened here. the splines on the rear otput shaft and the splines on the corresponding tranfer box coupling have sheared/stripped. yes? possibly because no anti seize grease fitted? how would that coupling strip teeth whilst cruising? i could sort of understand if it was some huge power say in low range etc. has not something seized within the transfer and found a weak point to keep 'moving' like that coupling?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1808 ![]() ![]() |
I replaced my gearbox just last week due to various driveability issues, and upon removal, found the splines were very worn on both the gearbox output, and transfer box input.
The splines don't break off in torsion, they wear away through fretting corrosion. The grease helps prevent this. Phil |
Another member here had his D4 box rebuilt by ZF Sydney for $4400. They are continuing with that same deal for a full transmission rebuild including output shaft. ZF told me most 6HP26s (most are from other makes) get to about 180,000km, although they have seen them get to 700,000. ZF advised that at 240,000 km the stator bush and TC are likely to be worn.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I have a 2010 and my replacement transfer box came from an early 3.6 V8 so it certainly works backwards. |
Thanks. What happened to your transfer box and what mileage? ______________________________
It had an oil leak. Its a very long story and quite interesting. I have a couple of pictures. When I have time I will write it up!
G'day PHIL Do you have ZF part numbers? How hard is it to get the tranny out? Can it be done at home on a slab? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Vogue tdv8 08MY poverty pack - wow |
Phil
I've bought another transmission & transfer box which fortunately has an identical ZF spec number of 1068 020 075. I found a ZF spec list that says all except very early 3.6 tdv8s had the same spec number. This is in contrast to D3/4s which listed lots of different ZF spec numbers. Many of the RRS tdv8s had a transmission with the same spec number. However, it wasn't used on any D3/4.
I spoke to the mechanic on Friday. There's not many L322s here, mainly D3/4s. So he hasn't done a L322 tranny swap before. As my L322 replacement box looks a lot less used and has the same parts list/manufacturers spec number as the old box, I'd like to fit the entire thing including the newer mechatronic. However, it sounds like the tranny ECU is VIN specific.
The pic is upside down and back to front for some reason Thanks ______________________________ Vogue tdv8 08MY poverty pack - wow |
And the tumbleweed rolls past. ....
