Home > Technical (L322) > Smoke from under the bonnet |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
difficult to diagnose something like this...could it have been water on the exhaust or a shredded belt? ... - .- -.
8th Jul 2015 9:46pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1695 |
Could it have been the FBH letting off steam... (thinking about it I talked myself out of that cos they are temp related and I doubt it would have cold enough to trigger)
8th Jul 2015 10:10pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
It is possible it's something not serious, like a carrier bag stuck to the exhaust. - if you feel able, you could look with a good torch, underneath in off-road height, just peering under on your side. And when completely cold, maybe feel around the manifolds, for melted remains etc.....
8th Jul 2015 10:18pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
My ac compressor clutch have off a fair amount of smoke when it went a few weeks back. But as said it could have been almost anything so best to take a look and use your nose to try to smell burnt electrics / plastic etc. |
8th Jul 2015 10:37pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Is it not the depths of winter down under this time of the year? Does anyone know what temp it is? As would rule out FBH |
8th Jul 2015 10:59pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8486 |
Could be the fbh, wasn't that warm in Sydney today.... Certainly cold enough for it to run. There is nothing that can't be fixed with a hammer😜😜
8th Jul 2015 11:10pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
As tractor engines are notoriously smokey nearly all the time its most likely that the wind was blowing the wrong way.
8th Jul 2015 11:30pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Well he said he filled up with desiesel so I'd go with the Fuel burning heater , it's certainly cold enough right now even here .
9th Jul 2015 2:14am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
FBH |
9th Jul 2015 9:56am |
i thought FBH, but OP says it didnt smell like diesel ? ... - .- -.
9th Jul 2015 10:08am |
Blade74 Member Since: 01 May 2015 Location: Sydney Posts: 55 |
I started it this morning and no smoke.
9th Jul 2015 10:25am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
More than likely it was the FBH. When the FBH runs, the smell is more like burning 'paraffin' rather than the diesel exhaust smell you get from running the engine.
9th Jul 2015 12:27pm |
I think you're right Discotigger and as others have said.
9th Jul 2015 12:52pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
FBH has three functions really.
9th Jul 2015 5:00pm |
