Home > Technical (L322) > Smoke from under the bonnet |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
It's a quirk of the FBH, sometimes when you do a short run in cold weather the FBH will kick in to warm up the car and engine, but when you then stop the FBH carries on to burn off any remaining diesel in the heater. That's when you're most likely to get the smoke and smell. It usually comes from the FBH exhaust which is located under the front passenger side wheel arch (Left hand side of vehicle if you've got a Right hand drive motor).
11th Jul 2015 8:59am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2524 |
Spotted the front wheel smoke this morning from my newly-acquired 4.4 TDV8 after a short run with the temperature around 8 deg C. The Topix build info show park heater not fitted which I had previously interpreted as FBH not fitted, but apparently not so, just the park heater function not available. I wasn't aware of the distinction.
17th Aug 2015 1:01am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Why would you want to disable it? It warms the engine up faster so your cabin heats faster and also gives you a small fuel saving as a result.
17th Aug 2015 6:14am |
Its never cold enough to warrant the embarrassment of the vehicle emitting smoke from around the engine in public. FBHs are not generally fitted to Oz vehicles so no-one knows the explanation and a well-meaning person may call the fire brigade thinking the vehicle is on fire. |
17th Aug 2015 8:47pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
It will usually smoke only the first few times it fires up for the winter, and if it hasn't been used for a while. It won't/shouldn't smoke as a matter of course.
17th Aug 2015 8:57pm |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
The FBH can be pretty embarrassing - it strikes me as the most ridiculous and archaic solution to the problem for such an expensive and supposedly advanced car
I'd say the same in the UK, they're fairly rare in passenger cars, and with those that do have them, i'd bet few of the owners even know they do. Really only common in scandinavian countries and eastern europe i would think. But i've never seen a news report of someone's car being mistakenly dowsed by the fire brigade in the UK, given all the Diesel range rovers have them, i'd expect to see plenty of news stories about it if it were the case. Unless random car fires are a big problem down your way i don' think i'd worry about it. If you get the remote for it and activate it you'll also be able to make use of the remote vent function - gets fresh air circulating before you get in the car. |
18th Aug 2015 12:09am |
I would hazard a guess that the diesel heater in your California is the same as that in the FF. Possibly a different model of Webasto, but fundamentally the same thing. There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black. KIA E-Niro 4+ 2021 Discovery 5 D300 MHEV commercial |
18th Aug 2015 6:48am |
^ I would say so Boat heaters , Truck heaters and car heaters all usually Webasto .No competition bar a few small time players . 2008 MY Supercharged
18th Aug 2015 7:45am |
Eberspacher are their main competitor. Cab heaters are normally either Webasto or Eberspacher, i wouldn't call Eberspacher small time though.
18th Aug 2015 12:05pm |
Total brain fade
19th Aug 2015 1:21am |
