Home > Technical (L322) > Smoke from under the bonnet
Blade74
Australia
Last night I stopped and filed up my car with diesel.
I drove home from the petrol station (5mins) and pulled up at my house to open the garage door.
Smoke was coming out from the front of the car and I could see it in front of the headlight.
It definitely wasn't diesel smoke it was some other smoke and smelled different.
I quickly turned of the car for fear of a fire.
Any ideas?
Could it be the alternator on the way out?
Post #336537 8th Jul 2015 9:32pm
difficult to diagnose something like this...could it have been water on the exhaust or a shredded belt? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #336538 8th Jul 2015 9:46pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Could it have been the FBH letting off steam... (thinking about it I talked myself out of that cos they are temp related and I doubt it would have cold enough to trigger)
Sorry Ash
2016 SDV8 AB
Post #336540 8th Jul 2015 10:10pm
johnboyairey
It is possible it's something not serious, like a carrier bag stuck to the exhaust. - if you feel able, you could look with a good torch, underneath in off-road height, just peering under on your side. And when completely cold, maybe feel around the manifolds, for melted remains etc.....
-or...Does/did it smell of hot oil?
Post #336544 8th Jul 2015 10:18pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
My ac compressor clutch have off a fair amount of smoke when it went a few weeks back. But as said it could have been almost anything so best to take a look and use your nose to try to smell burnt electrics / plastic etc.
Post #336551 8th Jul 2015 10:37pm
Is it not the depths of winter down under this time of the year? Does anyone know what temp it is? As would rule out FBH Thumbs Up
Post #336555 8th Jul 2015 10:59pm
Could be the fbh, wasn't that warm in Sydney today.... Certainly cold enough for it to run. There is nothing that can't be fixed with a hammer😜😜
Post #336557 8th Jul 2015 11:10pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
As tractor engines are notoriously smokey nearly all the time its most likely that the wind was blowing the wrong way. Shocked
Take a look at your exhaust manifold and directly above it, most likely you have a slight oil leak.
Clean white rag test works well, run it along the underside of rocker cover where the gasket is.
The BMW V8 is a shocker for drips hitting the manifold.
Did you notice a strong oil burning smell?
Post #336561 8th Jul 2015 11:30pm
Well he said he filled up with desiesel so I'd go with the Fuel burning heater , it's certainly cold enough right now even here .
I have probably the only petrol FBH in Australia and even mie has kicked in automatically to assist cabin heating once or twice . 2008 MY Supercharged
Post #336578 9th Jul 2015 2:14am
wealy
FBH
Post #336599 9th Jul 2015 9:56am
i thought FBH, but OP says it didnt smell like diesel ? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #336603 9th Jul 2015 10:08am
Blade74
Australia
I started it this morning and no smoke.
Looked under the bonnet and nothing strange.
No oil leaks.
Drove it to the city and back with no issues.
No warnings on the dash or anything weird happening.
No more smoke.
Post #336605 9th Jul 2015 10:25am
Discotigger
More than likely it was the FBH. When the FBH runs, the smell is more like burning 'paraffin' rather than the diesel exhaust smell you get from running the engine.
I've had people getting alarmed at petrol stations when, during winter if it's cold, after filling up with fuel and starting the FF, the FBH kicks in and sends a cloud of smoke out from under the passenger wheel arch. It can be funny to watch sometimes, as they think your car is about to go up in flames...only we FF Doozel owners know better!! Laughing
Post #336617 9th Jul 2015 12:27pm
Blade74
Australia
I think you're right Discotigger and as others have said.
FBH.
It didn't smell like diesel or electrical but paraffin sounds close.
What is the purpose of the Fuel Burning Heater?
I do know of a story of a guy who had a FFRR go up in flames a few years ago.
So yes was very paranoid!!!! 😳
Post #336621 9th Jul 2015 12:52pm
Zirconblue
FBH has three functions really.
First is to help the engine warm up quicker by warming the coolant, as diesels take longer to reach optimum temperature than a petrol engine. Which is why they have the FBH as standard. Engines aren't efficient until they get up to temperature, so getting it up to temp quicker makes them use less fuel over all.
Second is linked to the first. If the engine isn't warm then neither is the cabin heater, so warming the coolant with the FBH warms the cabin up more quickly.
Thirdly it can be configured as a parking heater, either on a timer or a remote. So it'll warm up the cabin in advance of you getting in.
Post #336667 9th Jul 2015 5:00pm
