![]() | Home > General > xenons |
Those are specifically bi-xenons though. As there are 3 types one must be careful not to confuse them. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
point taken, and good luck on your search.... |
I'd only buy them if they were a super deal - they may not work after all. |
yours look ok to me DAN... ... - .- -.
They look good, but at night I keep trying to flick to main beam only to discover that it's already on |
dont drive at night then ... |
Bi-Xenons. ![]() ![]() |
I was under the impression that all facelift lights were bi-xenons (which is why often simply the term 'xenon' is used).
From Microcat 2002-2009 there are 74 part numbers for the headlights! Obviously divide that by 2 for left/right that still gives 37 variations!
I just checked - curious. |
Unfortunately they don't seem to put a propper part number on them?
dan they do an after market bi xenon bulbs that do the main and high so you dont need to change the whole headlight
Pre-facelift had the 3 different headlight options. I was under the impression that they had done away with the sillyness post facelift. I'm going to check next time I stop by the dealer - I'd like to know if this was available through MY09... Dave, aftermarket xenons? ![]() ![]() Dan - that is strange. All the other lights I've seen or seen pics of have the part #'s right on the sticker you've pictured and they often end in LPO as in your pic... I'll see if I can check my lights in the next couple of days. Maybe I can identify and photograph the shutter solenoid easily - you could then just look and see if it's there in yours. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
