Home > General > xenons
Page 3 of 3 <123
dan_uk_1984
Nope, insane amount of options. Verify with Microcat yourself if you don't believe me!
I take it you have Bi-Xenons? Could you verify how yours work? Ie what bulb comes on when?
The part number on the light is too long for a LR part number + it's not recognised in Microcat Sad
I'm loathed to open the lights up to see if they have the flap and motor etc, but maybe if you can point me in the direction of what i'm looking for?
Dan
Post #33729 26th Oct 2010 11:30am
dan, get someone to put the lights to main and look at the xenon, you can see the flap move [if you have one that is] ... - .- -.
Post #33739 26th Oct 2010 11:51am
dan_uk_1984
Up against a wall I can see no increase in light from the xenons though. The only difference is the middle Halogens come on. Which looks stupid because against the pure white they look orange Big Cry
Post #33741 26th Oct 2010 11:53am
those crappy halogens are only there for show and probably a legal requirement [flashing etc]
..as the halogen mains aren't any use , i've put my drl leds in my mains and i use the fogs as mains now.... ... - .- -.
Post #33743 26th Oct 2010 11:56am
SteveMFr
Site Sponsor
I did, Dan, I did! That's what I posted last night with the comment 'unreal'. I was only answering Tim as he mentioned the pre facelift lights. I guess I needn't have mentioned my impression again. (I actually typed that shortly after I got into the office at about 7:15 AM - long before the caffeine actually took hold. Much too early for my generally-sleep-pampered brain. Took me another couple of hours before I finished the post, tho. Due to work - not lack of caffeine Razz )
Still interested in finding out if halogens were standard - or even available - in MY 09.
Dan
I have the Bi-Xenons: dip = xenons only, main = xenons w/shutter open and halogen. Mine is an older car updated too, though.
I know the PN is not correct - the list in Microcat for 06 and later headlights is not that terribly long and I tried to make sense of some portion of that PN. Still strange.
I was hoping to be able to see something through the larger rear opening in the lights. We'll see. Literally. Cool
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #33767 26th Oct 2010 2:45pm
dan_uk_1984
This is the inside of my headlight, I cant see a solenoid/motor to move the shutter:
26102010045 by d86cfv, on Flickr
26102010044 by d86cfv, on Flickr
26102010046 by d86cfv, on Flickr
Post #33805 26th Oct 2010 5:40pm
SteveMFr
Site Sponsor
Hi Dan,
Finally got around to looking today - tried to take pics but I only had my phone and it was just way too sunny out to get a pic into the dark light.
The news is - you're not bi.
Very Happy sorry. Couldn't resist.
The servo is immediately visible on bottom of the Xenon reflector (2 brass worm gears). I'd still check the alignment - and if nothing else helps, pick up a pair on the bay, swap and sell yours. With any luck, you might even come out ahead.
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #34334 29th Oct 2010 8:31pm
dan_uk_1984
That's certainly true! Idea
I might look for a pair on the bay then, altho I think the wiring will need modding slightly as they've only connected up half the wires and left the others to turn green. Looking at the wiring diagram these operate the shutter.
They did such a shoddy job, it really is unbelievable that they can get away with charging 2K to do this, and then sell the parts they've taken off your car for another 1K.
It was these cowboys: http://www.dcc4x4sidebars.co.uk/productView.php?pID=83&cID=4
Post #34343 29th Oct 2010 10:20pm
SteveMFr
Site Sponsor
So I assume they didn't use the oem connectors, just spade connectors?. I have an extra set of the oems - you'll likely need them for the fog lights too. And the GBP89 they're selling them for on the bay... Those people deserve to be smacked. PM if you're interested.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #34399 30th Oct 2010 2:33pm
dan_uk_1984
They used OEM for the conversion, but then they had lots of wires left over that they just left cut and dangling all over the place.
Post #34402 30th Oct 2010 2:37pm
Page 3 of 3 <123
