Home > General > xenons
Page 1 of 3 123>
m10rng
United Kingdom 2004 Range Rover HSE Td6 Java Black
xenons
guys i want to make my front lights brighter, i currently got bi-xenons but want more.
where do i start looking....bulbs....kits??
Post #33398 25th Oct 2010 1:43am
iT LAD
Scarey should be able to help you, he's quite good with lights...
Post #33400 25th Oct 2010 6:04am
dan_uk_1984
Do you want brighter or blue-er?
I've found the bi-xenons on my 53 to be far superior to the Xenons on my facelift Sad You may be dissapointed in output if you change them. But meh.
Post #33417 25th Oct 2010 8:54am
Re: xenons
Bow down rob.....
you cant get any better than the bi-xenons on yours ..as you know when you put your lights on high beam , a flap goes up and makes the dipped into high beams..the halogens are only there for show and flashing other motorists , and when in high beam only 10 volts goes to them...as DAN says if you want bluer light then replace the bulbs to 6000k ones [OE is 4300k] .....if you really want more light then spots are the only answer ,but then that would spoil the look of the front.. ... - .- -.
Post #33448 25th Oct 2010 10:47am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I must admit that I had adaptive Bixenons on the RRs with the additional driving lights, which gave a great range on the country roads round here. I don't know what difference there is with the FFRR headlights but I haven't found their range to be less than the combined driving lights and main beam headlights of the RRS. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #33471 25th Oct 2010 12:05pm
SteveMFr
Site Sponsor
Are you sure they're working properly? It's not factory wiring, after all.
I'd check the wiring and the adjustment. My facelift Xenons are fine. I don't know if they're much better than the earlier xenons, but they work as well or better than any other xenons I've driven with.
Can you hear the shutter when switching between main and dip beam?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #33577 25th Oct 2010 6:47pm
dan_uk_1984
No, because they are xenons not bi-xenons. If you have a shutter you have bi-xenons.
Post #33580 25th Oct 2010 6:58pm
so on yours DAN you have a hid bulb for dip and a separate hid bulb for main as opposed for a pre -facelift where there is only one hid for dip and main... ... - .- -.
Post #33587 25th Oct 2010 7:12pm
Tim in Scotland
If a Xenon lamp has a slightly pink tinge to it that is also a sign that it is getting near to failing 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #33589 25th Oct 2010 7:16pm
dan_uk_1984
Pre-Facelift with Bi-Xenons, as per Vogue:
Xenon Bulb - used for Dipped, with shutter dipping the beam. Xenon also used for Main beam when shutter moves out of the way.
Halogen Bulb - This is used as well as Main beam and Flashing (you cant flash with a xenon as the bulb takes a few seconds to warm up)
Facelift with Xenon:
Xenon Bulb - Just used for Dipped.
Halogen Bulb used for flash and main.
Facelift with Bi-Xenon As pre-facelift Bi-Xenons.
Post #33590 25th Oct 2010 7:17pm
nearly all clear now , but is there a choice of lights on the facelift ... ... - .- -.
Post #33591 25th Oct 2010 7:19pm
dan_uk_1984
Yep.
Xenon, or bi-xenon I believe. Microcat seems to back this up. They also did a Halogen only headlight. Possibly poverty SE spec?
Post #33594 25th Oct 2010 7:24pm
confirmed ,the SE does indeed have only halogens for both dip and main.. ... - .- -.
Post #33595 25th Oct 2010 7:26pm
dan_uk_1984
These are the bad boys I need:
http://cgi.ebay.co.uk/range-rover-L322-06-...4aa5b2251f
But whether the hack and slash job the conversion company did can ever be repaired to make fully functioning bi-xenons again, I dont know.
Post #33596 25th Oct 2010 7:27pm
i have been looking for a replacement unit for mine in the last few weeks and i've noticed quite a few units like that DAN and with a lower price as well... ... - .- -.
Post #33602 25th Oct 2010 7:34pm
Page 1 of 3 123>
