Home > Maintenance & Mods (L322) > Flip up cup holder fix |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
nice job, wiki'fied.. ... - .- -.
2nd Feb 2015 3:06pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Thank you sir Stan,
2nd Feb 2015 8:38pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Great write up wd. |
3rd Feb 2015 6:13am |
MY 2010 5.0 SC Galway green and sand interior!!
3rd Feb 2015 7:05am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
My spring broke two years ago and has been manual pull and push for years |
3rd Feb 2015 12:16pm |
kruger2002 Member Since: 19 Jul 2013 Location: Newbury Posts: 70 |
Very timely. Mine went a couple of weeks ago and I was just looking up how to fix.
3rd Feb 2015 8:16pm |
If it dont work.......burn it!
3rd Feb 2015 9:28pm |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Thanks Welshdragon, very helpful. On my 2004 the guide pins and tracks are different. The tracks on the housing are molded in and closed. The pin on the bottom is metal but the upper pins are small about 8mm ovals. One that broke won't glue with ABS glue. Trying superglue. The other one is gone. Not sure how to sort that one out yet but will post a pic when I do. Obscene price is the mother of invention.
28th Jun 2015 2:24am |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
I had a look at mine again before I started stripping it down and found a half melted sweet, a small crayon and a 2p coin in the bottom. After a bit of fiddling with long nose pliers and a screwdriver with blue-tac on the end (to lift out the coin and broken crayon bits) its closing again Previous owners rug rats must have used it as a secret hiding place |
29th Jun 2015 11:07am |
OK mine is back in. Only one ABS guide pin is holding but is is working. Probably won't use it much but it looks much better. All kinds of stuff under the main console just forward of the shifter. Total puzzlement how it got there. |
29th Jun 2015 3:35pm |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 |
I did a similar fix on ours yesterday. I used a couple of small screws to replace the two broken pins (I only spotted one broken pin last time). I did have to enlarge the grooves with a dremel, but one of the abrasive bits was just the right size so it was fairly straight forward.
18th Apr 2016 2:55pm |
