Home > Maintenance & Mods (L322) > Flip up cup holder fix
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Yesterday drivers cup holder in the centre console failed to close and stay shut, checking how much a new one would be I nearly fell off my perch, (part number FJI000020PUYG at £ 160 ) Shocked Shocked
So here is a fix if yours will not shut.
The cup holder has always been a bit temperamental and when open, the lid part had always touched the centre console so now was a time to find out why.
To take the centre console apart look at this link, ( ) no need to take the selector handle or hand brake grip off as there is room for taking the cup holder off with a chubby screw driver T 20 end, 3 screws.
Top screw had a washer in place.
Picture 3
The 2 lower screws, second one next to the one in the picture but hidden
Picture 4
And its out.The 5 screws T10 and red arrow plastic push fit to remove.
Picture 5
Undo 5 T10 torque screws and remove panel.
Picture 6 and 7
Retractable spring was fine and the tabs that locate in the body housing where good. If these are worn a simple 2mm stainless bar would replace these by drilling through the plastic.
The slide tabs are metal.
Picture 8
Locking mechanism when you push down to raise the cup holder from home and to lock when returning, no faults here either.
Picture 9
Need a clean I think!
Note all teeth and guides are good.
Also note how the spring is seated for re assembly Thumbs Up
Picture 10
Plastic pivot on the cup holder to remove, these are push fit on.
Picture 11
This locks the cup holder in place when open and should work freely, mine was sticky with coffee, cleaned up and freed up with wd40 nicely. Now I know why the cup holder hit the top of the centre console when open.
Picture 12
The end panel splitting away from the main body when the cup holder is closed.
Reason, the cup holder was pivoting inside the main body due to the top tab missing and not guiding in the slot.
Picture 13 - 16
Top locating tab missing hence the body of cup holder would not stay closed.
Arrow 2.5mm hole drilled ready for new tab to run in guide.
Tab cut from 2.5mm stainless rod, bent 90 deg and push fit in, its a snug fit Thumbs Up
Picture 17
The next issue was that the cup holder was catching the inside of this tab, just enough to stop it closing fully Evil or Very Mad
Filled off a corner and a groove in the plastic body of the cup holder so it would miss, works a treat now Mr. Green
Picture 18 - 19
Care to refit all together and test.
Fit it into the console and retest before screwing down the centre console.
Well that just saved me some pennies, it works for me and better than before ! Thumbs Up
Hope it help someone who has same problem. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #281931 19th Sep 2014 5:19pm
nice job, wiki'fied.. Thumbs Up ... - .- -.
Post #309986 2nd Feb 2015 3:06pm
Welshdragon
Thank you sir Stan, Bow down Thumbs Up Thumbs Up
I thought it might help someone in the future as these are quit expensive new now. If it dont work.......burn it!
Post #310065 2nd Feb 2015 8:38pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Great write up wd. Thumbs Up
Post #310128 3rd Feb 2015 6:13am
ebajema
Thumbs Up Thumbs Up Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #310131 3rd Feb 2015 7:05am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
My spring broke two years ago and has been manual pull and push for years Thumbs Up
Post #310201 3rd Feb 2015 12:16pm
kruger2002
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Very timely. Mine went a couple of weeks ago and I was just looking up how to fix.
Thanks. Currently - 55 FFRR S/C and loving it
Post #310335 3rd Feb 2015 8:16pm
Welshdragon
Thumbs Up Thumbs Up If it dont work.......burn it!
Post #310361 3rd Feb 2015 9:28pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Thanks Welshdragon, very helpful. On my 2004 the guide pins and tracks are different. The tracks on the housing are molded in and closed. The pin on the bottom is metal but the upper pins are small about 8mm ovals. One that broke won't glue with ABS glue. Trying superglue. The other one is gone. Not sure how to sort that one out yet but will post a pic when I do. Obscene price is the mother of invention.
Good thing the E brake handle didn't need to come off because mine wasn't letting go.
Post #334784 28th Jun 2015 2:24am
Brian
I had a look at mine again before I started stripping it down and found a half melted sweet, a small crayon and a 2p coin in the bottom. After a bit of fiddling with long nose pliers and a screwdriver with blue-tac on the end (to lift out the coin and broken crayon bits) its closing again Smile Previous owners rug rats must have used it as a secret hiding place Smile
Post #335018 29th Jun 2015 11:07am
doclees
OK mine is back in. Only one ABS guide pin is holding but is is working. Probably won't use it much but it looks much better. All kinds of stuff under the main console just forward of the shifter. Total puzzlement how it got there.
Post #335064 29th Jun 2015 3:35pm
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I did a similar fix on ours yesterday. I used a couple of small screws to replace the two broken pins (I only spotted one broken pin last time). I did have to enlarge the grooves with a dremel, but one of the abrasive bits was just the right size so it was fairly straight forward.
I left the cupholder itself out initially when I reassembled so i could get in with a grinding wheel on the dremel to grind the tips of the screws flush with the housing before installing the cuphoulder with the two plastic clips. Works a treat now.
Post #382729 18th Apr 2016 2:55pm
