![]() | Home > Maintenance & Mods (L322) > Lift Kit for 2004 TD6 vogue |
abs123 Member Since: 03 Jun 2015 Location: London Posts: 20 ![]() ![]() ![]() |
Hi all
so would this allow me to have safely have a higher suspension setting at normal ride height?
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
The good thing with the Tool is you can raise the suspension only when needed OR all the time (get an alignment then).
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
I'm running 32" tyres and have mine about 50mm above standard, been like it for about a year, I used an IID tool to raise it, Johnsons rods are IMHO a waste of money, you still need to get the system set up correctly as the height sensors have such a small length of movement they will not be right "out the bag" and if you have to pay some one to set it up, they may as well set it up 2" higher anyway....
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2592 ![]() ![]() |
Yes, buy some Brokeback American pick-up where you can buy all the bits cheaply off the shelf. It will still be pointless, but you'll have saved a load of money and hassle. |
Unnecessary quote removed
IID tool, all Britparts retailers offer them, some are even online/ebay, etc. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Well raising the car is obviously going to affect it's centre of gravity, i expect there is a reason LR have a 30mph speed limit for 'off road height'. I'm not saying it's impossible or shouldn't be done, loads of people with metal suspension raise their cars for off roading without crashing. But you did ask if it was safe, clearly it will affect your cars high speed stability (ie side winds) and your ability to swerve around obstacles. You'd have to limit your on road speed to compensate i would think. If you're running the bags at the higher pressure then the consequences could be worse if one failed at speed. |
Mine is an off roader and I am prepared for a compromise, would not advise raising the ride height for normal driving, my standard height is raised but I have kept the motorway height at the standard level, this gives problems with tyre wear as the suspension was adjusted at standard height and as I've done a lot of motorway work recently the rear tyres have worn very unevenly, I'm currently experimenting with different Camber settings on the rear...
I think will give up on the idea then |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
If you just want an offroad type tyre look you could consider getting some 19" wheels (255/55R19) and fitting Goodyear Duratracs. They are LR homologated, but it would probably be as well to tell your insurers.
would i be able to fit the 255 55 19 mud tires on without modding the suspension and keeping it standard?
No, would be fine at standard height, no clearance issues... Pete
Here you go Goodyear MTR's 255/55/19 on Standard 2003 19's
