![]() | Home > Maintenance & Mods (L322) > Lift Kit for 2004 TD6 vogue |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Pete, if you run a lift permenantly, did you allow the rubbers in the suspension to re align by slackening the suspension bolts off. if not you could be in for a new set of arms prematurely. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
NMJ, we've just talked him out of those.... far too wide, suspension problems and four new wings....!!!
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1404 ![]() ![]() ![]() |
Assuming it's the Haylands pictures you like, 255/55R19 would have been a standard size on a 2004 car and would not protrude beyond the wheel arches. Only Range Rovers since 1988 |
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 ![]() ![]() ![]() |
Im running 33x12.5R20 with 30+ BMW offset rims,
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Not wanting to rain on your fun, but, when I went on to 33"'s on my Jeep, it didn't half knock the performance for 6 (and it's a high power 4.0 lt). So much that I am now thinking about a higher diff ratio, which is fine for a Jeep as you can get just about every ratio you can think of and then some. But as far as I'm aware there are no alternative ratios for the ffrr, in fact as far as I know you can't even get lockers |
the td6 is an incredibly torquey motor, little difference in performance. only a bit on the fuel economy.
Hmmm, engine tune, ecotuned gearbox, I'd like to know how you get on with them...........
Eeeer yes you have mate... all FF's have it...
Well I haven't got hill decent control for starters, the bong of death and the screen of doom tell me every now and then......... you know, those days when it can find anything wrong, so mine thinks I'll tell him about the HDC, but only for a nano second, just to get him worrying |
Well fix it then..... |
...mine is the poor mans bmw version...just the last one
Pete, I got bigger worries than taking the transfer box out and stripping it! Plus I have found this handy feature, you can lock it in low first gear |
Touch screen for me |
