Home > Technical (L322) > 3.6 TDV8 EGR options? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
It is to a standard TDV8
17th Jan 2015 1:27pm |
I beg to differ. Although I should have said RRS, which is a similar weight to the D3. The FFRR is a fair bit lighter than D3/RRS
17th Jan 2015 6:32pm |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 |
@ziggy
17th Jan 2015 7:23pm |
nondiscopaul Member Since: 06 Mar 2015 Location: Midlands East Posts: 7 |
My bmw 120d was recently down to about 5hp, with check engine light on. 1st gear...max of 3mph. First job...clean erg valve. Easy, dirty job and very dirty. No improvement, but looking inside the inlet manifold, etc. showed everything deep in a the black sooty stuff. So its the turbo.
6th Apr 2015 2:03pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Spoke with MOT tester last week and they now are checking DPF's are functioning as part of the MOT so... NO you cannot remove or MAP it out or it will fail the MOT |
6th Apr 2015 7:09pm |
As above
6th Apr 2015 8:12pm |
OK, accept that Particle Filter has to be there for the MOT... (being there...might be different from mapped out and/or hollowed out. Thanks for the suggestion.) My journeys are 99% duel carriageways and I will never drive in London, etc. Looking at the method and theory can't see any increase in emissions, or evil particles of significance with or without this filter during the remaining life of the car.
6th Apr 2015 9:56pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Sorry to resurrect this thread but would a failing EGR valve cause an "ENGINE SYSTEM FAULT" that IIDTool reports as a turbo actuator fault?
25th Jun 2015 8:21am |
Oh dear Alan, that sounds worrying sir... As I’ve said before... I wouldn’t risk driving a 3.6 with any turbo/egr related fault! Most that have, report they can turn it off and reset when re-starting so have continued using the car, usually until it gets worse/more irritating then finally get the fault looked at! The EGR’s get changed and within a very short space of time the R/H Turbo will (at worst) explode throwing its internals back through the induction system...
25th Jun 2015 10:02am |
So what do you recommend in this situation Craig?
25th Jun 2015 10:41am |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
@ alanm_3
25th Jun 2015 11:32am |
Yes, the errors are related to the turbo actuator and like you there are as many theories as people who look at the car! I just wondered if the EGRs were the cause of the apparent turbo actuator error. Cause and effect etc
25th Jun 2015 11:58am |
As said above Alan, its not a forgone conclusion it’s one or the other, or even related to either! & i would only be guessing if i advised you further So... You really need to get it checked out by someone knowledgable asap... |
25th Jun 2015 11:59am |
That's what I did when it first appeared Craig, but as has also been said, opinions differ as to what the reasons are for this issue.
25th Jun 2015 12:02pm |
