Home > For Sale & Wanted > [Wanted] Removable tow bar |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
If you can't get one used then PF jones are doing them for about £200.
19th Jun 2015 5:40pm |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
I had a look thanks
19th Jun 2015 7:58pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Here's the whole thing £383
19th Jun 2015 8:01pm |
As far as I'm aware it is for the receiver and the detachable ball all the bits in grey in the picture in the top left. I don't think the receiver is available separately neither is the ball. I would give them a ring to check before ordering, but I'm pretty sure thats what you need.
19th Jun 2015 8:03pm |
Depends what you mean by 'bolts onto the subframe' - if you mean into the 50mm square receiver, then you should just need the link NMJ provided |
19th Jun 2015 8:07pm |
I've got the parts you need. Mine came with the whole shebang but I use a farmer's hitch to accommodate my bike rack brackets. Got the storage thingy too. Not far from you by the look. Junction 11 of the M42. Any good? |
19th Jun 2015 8:18pm |
If I hadn't just had to run the old FF to the garage to remove the same from the armature for fixing onto the new car, because I hadn't got either a spanner/socket big enough, or the strength to undo it (he had to use the big windy gun on it) then I would have had that off you! There is nothing that can't be fixed with a hammer😜😜
19th Jun 2015 8:33pm |
