![]() | Home > For Sale & Wanted > [Wanted] Removable tow bar |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
If you can't get one used then PF jones are doing them for about £200.
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
I had a look thanks
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7976 ![]() ![]() ![]() |
Here's the whole thing £383 |
As far as I'm aware it is for the receiver and the detachable ball all the bits in grey in the picture in the top left. I don't think the receiver is available separately neither is the ball. I would give them a ring to check before ordering, but I'm pretty sure thats what you need.
Depends what you mean by 'bolts onto the subframe' - if you mean into the 50mm square receiver, then you should just need the link NMJ provided |
I've got the parts you need. Mine came with the whole shebang but I use a farmer's hitch to accommodate my bike rack brackets. Got the storage thingy too. Not far from you by the look. Junction 11 of the M42. Any good? |
If I hadn't just had to run the old FF to the garage to remove the same from the armature for fixing onto the new car, because I hadn't got either a spanner/socket big enough, or the strength to undo it |
