Home > For Sale & Wanted > [Wanted] Removable tow bar
IanT599
I'm possibly getting a car with no tow bar. 2011 tdv8 AB. I've got a farmer plough one of my own but I'm looking for the normal removable one complete and possibly the frame it bolts too.
I'm waiting for the dealer to confirm if it has the tow bar frame under the car or not.
Thanks
**update**
Just need to get the removable part now and the storage for it as the one we are going for has the sub frame thing already.
Post #333355 19th Jun 2015 1:29pm
If you can't get one used then PF jones are doing them for about £200.
http://www.pfjones.co.uk/range-rover-2002-...w-bar.html
which seems a fair price, i would assume it comes with the storage tray which fits in the boot (mine did when i sourced a westfalia one a few years back) There is nothing that can't be fixed with a hammer😜😜
Post #333415 19th Jun 2015 5:40pm
IanT599
I had a look thanks
I can't work out if that is for both parts of the tow hitch.
I need the square part (receiver) that bolts to the sub frame and the swan neck attachment.
Post #333445 19th Jun 2015 7:58pm
Here's the whole thing £383 Thumbs Up
Plus electrics Whistle
Post #333447 19th Jun 2015 8:01pm
As far as I'm aware it is for the receiver and the detachable ball all the bits in grey in the picture in the top left. I don't think the receiver is available separately neither is the ball. I would give them a ring to check before ordering, but I'm pretty sure thats what you need.
this is the pic form the pfjones site.
Post #333448 19th Jun 2015 8:03pm
Depends what you mean by 'bolts onto the subframe' - if you mean into the 50mm square receiver, then you should just need the link NMJ provided Thumbs Up
Post #333452 19th Jun 2015 8:07pm
mzplcg
I've got the parts you need. Mine came with the whole shebang but I use a farmer's hitch to accommodate my bike rack brackets. Got the storage thingy too. Not far from you by the look. Junction 11 of the M42. Any good?
Post #333456 19th Jun 2015 8:18pm
If I hadn't just had to run the old FF to the garage to remove the same from the armature for fixing onto the new car, because I hadn't got either a spanner/socket big enough, or the strength to undo it Big Cry (he had to use the big windy gun on it) then I would have had that off you! There is nothing that can't be fixed with a hammer😜😜
Post #333464 19th Jun 2015 8:33pm
