![]() | Home > In Car Electronics (L322) > IID Fault code |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
No sir, those three codes appear on most FF's so are a generic issue |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
Not really, open circuit means there is a break somewhere in the system, could be the speaker has failed or wiring has worn through somewhere or their just not plugged in...
Oh right... what he said then.... |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 442 ![]() ![]() |
Do you know where the "B1A02-13 (2F) Speaker 2 circuit" is? I think that this could be related to the drainage. |
Ok, then please post your findings sir... |
How can "open circuit" drain power...?? Pete
That is a valid comment! It's just thàt I'm grasping for a clue where to search for the power leak.... It might be that fault codes could indicate where another circuit was leaking? The HVAC fan in the dashboard (that sucks air to measure the cabin temp) is always on. Even after I've replaced the FSR... |
As Craig says, those faults are on a lot of your year so ignore them they are red herrings...
Thanks for the advise, Pete, I'll do that! |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
CamTechCraig |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
Hey Erik, You have (or had) a very similar sounding issue as me (4.4 TDV8, HVAC system stays active draining 0.2amps all the time). I also have the two open circuit on speakers fault codes too. Did you ever get to the bottom of this issue, what was it for you? |
I investigated quite a lot back then (measured the different circuits / fuses) to find the source of the drain in the ffrr - drain was fixed after replacing the FSR and the BT module. Of course also replaced battery twice since then - now using an AMG battery that works fine.
Glad you were still subscribed to the thread! Thanks for that!
