Home > In Car Electronics (L322) > IID Fault code
Eirik34
Norway
IID Fault code
Hi, I'm currently searching for a power leak in the car. Have replaced the FSR, but with no effect.
After clearing the fault codes with the IID tool, I continue to get the following faults:
"•B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open"
"•B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open"
Anyone that knows anything about these codes? Where could there be a circuit open - i.e. where to start to search?
I also get this error message "•B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold".
Could anyone of these 3 faults have anything with the power drainage?
Post #333239 18th Jun 2015 10:30pm
No sir, those three codes appear on most FF's so are a generic issue Rolling Eyes
Don't waste your time with them my friend... Thumbs Up
Post #333240 18th Jun 2015 10:35pm
Not really, open circuit means there is a break somewhere in the system, could be the speaker has failed or wiring has worn through somewhere or their just not plugged in...
circuit current below threshold means it's not getting enough current.... could be a blow fuse....
There is an article in the WIKI to help find a power drain.... Pete
Post #333241 18th Jun 2015 10:36pm
Oh right... what he said then.... Bow down Bow down Pete
Post #333242 18th Jun 2015 10:37pm
Eirik34
Norway
Do you know where the "B1A02-13 (2F) Speaker 2 circuit" is? I think that this could be related to the drainage.
Post #333244 18th Jun 2015 10:42pm
Ok, then please post your findings sir...
Post #333250 18th Jun 2015 11:01pm
How can "open circuit" drain power...?? Pete
Post #333260 18th Jun 2015 11:32pm
Eirik34
Norway
That is a valid comment! It's just thàt I'm grasping for a clue where to search for the power leak.... It might be that fault codes could indicate where another circuit was leaking?
The HVAC fan in the dashboard (that sucks air to measure the cabin temp) is always on. Even after I've replaced the FSR...
Post #333269 19th Jun 2015 6:03am
As Craig says, those faults are on a lot of your year so ignore them they are red herrings...
Buy a cheap multimeter that reads amps, put it inline with the battery lead. Then start pulling fuses one at a time until you find the draw... that's the basic way....
Don't forget to leave the bonnet and door open for longer than 16minutes for the car to power down and be very careful when you replace fuses that are next to blank holes as putting one back in wrong could be an expensive mistake Pete
Post #333290 19th Jun 2015 10:02am
Eirik34
Norway
Thanks for the advise, Pete, I'll do that!
Post #333295 19th Jun 2015 10:12am
RR2008HSE
CamTechCraig Bow down Bow down Bow down
You have made my day. Whenever I use the IID I get those speaker errors showing up. I've been puzzled as the radio DOES work. I've just been procrastinating about it. To hear that it's an official "don't worry, they all do that" is very reassuring.
Many thanks.
Post #333686 21st Jun 2015 3:29am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Eirik34 wrote:
That is a valid comment! It's just th�t I'm grasping for a clue where to search for the power leak.... It might be that fault codes could indicate where another circuit was leaking?
Hey Erik,
You have (or had) a very similar sounding issue as me (4.4 TDV8, HVAC system stays active draining 0.2amps all the time). I also have the two open circuit on speakers fault codes too.
Did you ever get to the bottom of this issue, what was it for you?
Post #575641 10th Dec 2020 1:41pm
Eirik34
Norway
I investigated quite a lot back then (measured the different circuits / fuses) to find the source of the drain in the ffrr - drain was fixed after replacing the FSR and the BT module. Of course also replaced battery twice since then - now using an AMG battery that works fine.
Haven't had any power leakage since 2016 Smile !
Post #575664 10th Dec 2020 4:03pm
Siftah
Glad you were still subscribed to the thread! Thanks for that!
I have a feeling it's no the FSR - you mentioned in this thread the drain persisted after swapping the FSR too, but perhaps bluetooth module or similar is where I need to look. I think I'll be spending my weekend pulling fuses Smile
Post #575676 10th Dec 2020 5:12pm
