Home > Wheels & Tyres > Tyre Wear front to back..? |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 186 |
Thanks. Had the 4 wheel alignment done on my Disco3, which made a real difference.
13th Jun 2015 11:41am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I was commenting generally regarding all cars, not just Land-Rover products. The alignment is set at the factory, but should be double checked by the dealer when cars are delivered to them as part of PDI. Because after a car has been driven a bit everything settles and needs rechecking.
13th Jun 2015 12:00pm |
Some Mk2 Mondeos had that subframe issue too. 17 MY Corris Grey 4.4 VAB
13th Jun 2015 2:03pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
In theory the rears should wear out first as there is more power going to the rear but it does seem that the fronts tend to wear off their edges as some suggest and I seem to notice when ever I see any,wether incorrect pressure or just fast cornering ,who knows.I do like to swap my tyres round but am unable with the directional,i guess all motors are different.My works van ,a nv200 wears all 4 almost evenly with only front wheel drive,explain that?? |
13th Jun 2015 8:34pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
its a 50/50 power output to the fronts and rears .. ... - .- -.
13th Jun 2015 8:42pm |
Depends how much weight you're putting in the back.
You can still swap them front to rear?
Though the MK3 on which the X-Type was based didn't. |
13th Jun 2015 8:52pm |
I thought they put 60% to the rear? |
13th Jun 2015 9:09pm |
from the WM,
13th Jun 2015 9:30pm |
The original Range Rover and the Defenders have a 60/40 split.
13th Jun 2015 10:32pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 800 |
If you speak with AJS tyres, a well known and respected LR tyre fitter. They are adamant that when fitting a new pair, they should always go on the rear. |
27th Jun 2015 5:59am |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
I agree ^^ but does that apply to ALL cars?
27th Jun 2015 6:16am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
Don't know who told you that, but all Land Rovers / Defenders and the original Range Rover have always been 50:50 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
28th Jun 2015 8:12am |
Oh ok, i'd been told it by someone, and never having tested it i assumed it was the case.
28th Jun 2015 2:04pm |
