Home > In Car Electronics (L322) > Bluetooth retrofit |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Good day.Thanks for your last.u are are right mic has only 3 cables.Understood that swapping of cables 19-21,depending on which drawing u will use, does not affect function of mic.
21st May 2015 7:41am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
Hi.
21st May 2015 4:29pm |
Good mrng.
22nd May 2015 8:08am |
I used the chart in my earlier message and my microphone works fine.
22nd May 2015 6:45pm |
Good day.I changed mic with a new one but still i cannot be heart.Any idea what i have to further check so try solve this problem?????
27th May 2015 7:58am |
The only thing I can think of is that you have a break in the wires somewhere between the ULF and the front of the car.
27th May 2015 8:32am |
I was hoping to be something simpler since for me seems very difficult to make a new mic line.
27th May 2015 3:43pm |
Where did you get the first mic from ? Was it in the car already ?
27th May 2015 4:33pm |
No the mic was not in car.Bought it together with ulf.Second one bought is a new one.Have seen the site and noticed about mic connection under the centre consol.My car has ashtray instead of cup holder.So i am afraid that order reach the overhead mic connection i will have to remove the all console or not?just few parts of the console and that's it?
28th May 2015 3:27pm |
Sorry, I've never took the console apart.
28th May 2015 4:53pm |
Hi there.Have connected a mic directly in ulf and normally worked.So decided to check what is happening under the centre console which easier than take it off that what i was expected.
31st May 2015 6:24pm |
I've never looked under the console, sorry.
31st May 2015 6:52pm |
You are looking for C2044 on this diagram, with those coloured wires going in and out
31st May 2015 6:56pm |
Thanks your last.I tookoff once again centre console and i carefully relooked maybe for more than an hour almost all the looms in there but i found not and any connector either free or connected with relevant colors or even with just 3 cables.Afraid that i will not escape the visit to workshop.Bad luck
1st Jun 2015 2:39pm |
