Home > In Car Electronics (L322) > Bluetooth retrofit
Page 2 of 4 <1234>
mjdronfield
No problem. Let us know how you get on. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #321435 6th Apr 2015 1:19pm
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Just another question.As car is prewired shall i take as granted that microphone wiring runs all the way from head console till back to the trunk or is possible microphone wiring to stop under the center console.Is there any way to check it from the existing wires in truck?
Post #321572 7th Apr 2015 9:18am
mjdronfield
The wiring should all be there, just connect microphone to connector that's behind the overhead console near the interior light, don't do anything in the boot, 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #321619 7th Apr 2015 1:19pm
AKIS
Thanks and noted
Post #321643 7th Apr 2015 3:46pm
AKIS
mjdronfield hi again.Ready to proceed with installation but need a clarification.
Re 54 pin connector all clear and ready.
Where i am confused is what about the other two connectors the black purple and white one
Is the white one connected to the ulf and the black to the bluetooth antenna or these two connectors remain idle and i have to buy a new antenna cable for such a connection?
reason i am asking you is that in have seen in other posts that the white connector,in ulf,has the exact same shape with the black one connected in antenna while mine have different shape.
Thanks
Post #323977 23rd Apr 2015 2:03pm
mjdronfield
I have this connection for the antenna. It should be there in the car already
I then have the 54 pin connected.
Can't think of any others.
You will have to post some pictures if you want more information so we can see the connectors.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #324024 23rd Apr 2015 4:36pm
AKIS
so the black purple connector in ulf and the remaining white one in antenna.White connector i am speaking for as in attached photo
Many thanks
[img]http://www.fullfatrr.com/gallery/albums/userpics/10281/RR-BMW%20Bluetooth%20Pinout.pdf[/img]
Post #324113 24th Apr 2015 8:07am
AKIS
just to be more accurate white connector in red rectangular.
Post #324116 24th Apr 2015 8:14am
mjdronfield
Hi,
To be fair, I don't think it matters which way round the cable goes. One end needs to be on the ulf and the other end goes to the antenna. It just goes from the ulf to the antenna, that's it.
It needs to be the same cable, ulf one end, antenna the other.
I assume that there is only 1 cable in your car. You may find that the connector with the 90 degree bend in it is better on the ulf depending on the space where you mount it.
If you have 2 separate cables, you will just need one. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #324214 24th Apr 2015 5:01pm
AKIS
Once again many thanks for your help
Post #324243 24th Apr 2015 7:38pm
AKIS
Hi.Back again.I have just installed ulf after having re pinned 54 pin connector exactly as per chart in this threat.
iPhone paired and I can also see on screen the addrs book.
However I am facing two problems.
1.during phone call I can hear but I cannot be heart
2.when I am pressing face button on steering wheel is not activated the voice command but instead the last phone nr I have dialed is redialed.(ulf is MIT ses)
Any ideas how can solve problems please?
Post #328668 19th May 2015 6:38pm
mjdronfield
You have fitted the microphone into the space opposite the sunroof switch ?
Voice control needs to be enabled on the ulf. I used navcoder to do this. Do a search for navcoder. Not sure if a BMW dealer can do it otherwise. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #328674 19th May 2015 7:26pm
AKIS
Good day.Yes microphone fitted.Can it be a defective microphone or any connections problem?I have touched nothing else other than rewiring the 54 pin connector exactly as per chart.
Re voice commands noted and i will have a look for navcoder
Many thanks
Post #328713 20th May 2015 7:23am
mjdronfield
I believe there are only 3 wires for the microphone, and 2 of them can be the other way round and it still works....
I'll try and find the PIN numbers. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #328792 20th May 2015 4:22pm
mjdronfield
These are from the original wiring diagram in RAVE, so will be the OLD PIN numbers, but you can see the wiring setup....
So after the rewire they should be pins 1, 21 and 19.
I swapped 21 and 19 and it still worked.
The info is in the chart on the previous page.
Suppose it could be a faulty mic though......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #328795 20th May 2015 4:33pm
Page 2 of 4 <1234>
