![]() | Home > Technical (L322) > L322 fuel pump leak... |
Where is the leak coming from. You have two pumps, one in the tank and the other under a cover by the LR wheelarch?
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I'm not an expert on the TD6, but there should be 3 Fuel pumps.
You are right - the injection pump, tucked away under the inlet manifold, looks like a right pig to get at, lots of dismantling, coolant drain down, but it could just be some loose connection. Not for faint-hearted, also a couple of special tools for releasing sprocket from pump.
D8DEL Member Since: 14 Nov 2013 Location: AIRDRIE, North Lanarkshire Posts: 26 ![]() ![]() ![]() |
Hi guys, thanks for the replies and the guidance.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
They are quite prone to leaking. If it gets much worse, eventually it won't start.
acc Member Since: 06 Dec 2014 Location: Essex Posts: 6 ![]() ![]() ![]() |
If it is the pipe from the fuel filter to the injector pump, I had the same issue last year. The pipe also has a take off for the FBH. I found out it is a LR supply only part, but Craddocks got me one and with postage it wasn't cheap. £92:00.
Thanks for the replies guys.
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
Hi, did you have any luck sealing/sorting your fuel leak? 2018 Suzuki Jimny 2003 written off
