Home > Maintenance & Mods (L322) > roof rack fittings
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
roof rack fittings
hi all, i'm thinking of fabricating a roof rack for my range rover l322 2003. the only problem is i don't know what the fitting that locates into the roof looks like. i wouldnt want to loose it on the M6. if anyone has a sketch or photo hopefully with dimensions it would be great. thanks. Very Happy
Post #329909 29th May 2015 11:19am
Zirconblue
Can you get a Thule 'foot pack' from Halfords for a pair or Thule roof bars? You can buy them separately from the bars, and it'll give you the roof fittings, you can then modify the other end of the Thule parts to suit your rack.
Post #329910 29th May 2015 11:24am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
this add contains some FF Thule reference numbers. might be able to get working drawings or install pics off these?
http://www.ebay.co.uk/itm/Thule-Square-Roo...485d3bebe4 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #329938 29th May 2015 4:27pm
When you say 'fabricating', I'm expecting something more like a G4 expedition rack than a couple of Thule bars ?
Post #329949 29th May 2015 6:34pm
razzer
sorry for the late response my internet has been down, thanks for all your input, yes alistair im talking a full size rack to use on camping trips and to remove it for the rest of the time.
Post #330259 31st May 2015 5:25pm
verydisco is your man - if you ask nicely, he may send you some measurements Thumbs Up
Post #330260 31st May 2015 5:36pm
sako243
I can probably get you some measurements tonight. I've got the rack off at the moment. Ed
Post #330264 31st May 2015 6:02pm
sako243
Right I can do you one better - I've got a 3D model drawn up for you. Accurate to ~0.1mm the paint thickness varies the dimensions a bit.
If you want I can provide an Inventor model for it (or anything I can export from the Pro version so Step files etc, but not solidworks Embarassed)
[edit]Drawing hadn't updated with the cut out[/edit] Ed
Post #330294 31st May 2015 8:15pm
sako243
A few points I noted when Duckworth Dan and I fitted it and also when I removed it.
When installed these brackets don't sit flat because of the curve of the roof, the brackets on the roof-rack that sit these mounts follow that contour. However the middle one because of this bend meant that I had to cut ~3/4" off one of the 3mm plates that bolt the rack down so it could be installed.
When I removed the rack I think the central gap could possibly be widened because it crushed the paint around the bolt hole. But that's being picky (but then again we are on a Full Fat forum).
Any more questions let me know. Ed
Post #330295 31st May 2015 8:20pm
razzer
thanks sako thats really helpfull.
Post #330384 1st Jun 2015 10:42am
sako243
No problem - if you want a slightly higher resolution picture (for some reason it didn't export particularly highly) I can generate a better one tonight.
Similarly drop me with a PM with your email if you want the original model.
Since the rack's off at the moment I can probably get you some measurements of that more easily if you want as well. Ed
Post #330385 1st Jun 2015 10:46am
