![]() | Home > Maintenance & Mods (L322) > roof rack fittings |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 ![]() ![]() ![]() |
hi all, i'm thinking of fabricating a roof rack for my range rover l322 2003. the only problem is i don't know what the fitting that locates into the roof looks like. i wouldnt want to loose it on the M6. if anyone has a sketch or photo hopefully with dimensions it would be great. thanks. |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
this add contains some FF Thule reference numbers. might be able to get working drawings or install pics off these?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
When you say 'fabricating', I'm expecting something more like a G4 expedition rack than a couple of Thule bars ? |
sorry for the late response my internet has been down, thanks for all your input, yes alistair im talking a full size rack to use on camping trips and to remove it for the rest of the time. |
verydisco is your man - if you ask nicely, he may send you some measurements |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
I can probably get you some measurements tonight. I've got the rack off at the moment. Ed |
Right I can do you one better - I've got a 3D model drawn up for you. Accurate to ~0.1mm the paint thickness varies the dimensions a bit.
A few points I noted when Duckworth Dan and I fitted it and also when I removed it.
thanks sako thats really helpfull. |
No problem - if you want a slightly higher resolution picture (for some reason it didn't export particularly highly) I can generate a better one tonight.
