Home > Maintenance & Mods (L322) > Help - Can't jack car high enough
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Guys,
Silly question - where do I put my trolley jack so I can raise it hight enough to get the front wheel off..?
Tried the normal jacking point behind the wheel but can't get it high enough to raise the wheel off the ground?
Embarassed
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #311362 7th Feb 2015 2:40pm
I have a block of wood I use with mine - not ideal, but I don't really want to buy a special high liftt trolley jack.
Post #311365 7th Feb 2015 3:13pm
ebajema
Buy the Mercedes Sprinter hydraulic jack, plenty of stroke to get the wheels up Wink MY 2010 5.0 SC Galway green and sand interior!!
Post #311366 7th Feb 2015 3:18pm
Put it under the front wishbone...
Or put the car in off road height and use a large block of wood under the whole jack, safer that way
Don't forget to leave a door open so the FF doesn't try to self level when you have it jacked up.... Pete
Post #311369 7th Feb 2015 3:23pm
ebajema
^ plus 1 on the location of the jacks under the wishbones, use to do that on my 2006 SC with the normal trolley jack until I got the Sprinter bottle jack for flat tyres (happened twice in Nigeria).
In other words, Sprinter jack for travelling needs, trolley jack at home (I have a 5 tonnes here as well). MY 2010 5.0 SC Galway green and sand interior!!
Post #311371 7th Feb 2015 3:26pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
After reading this thread I tried to jack up my car via the wishbone. I lifted the car ok but the small trolley jack was just lifting off the ground on one side due to the angle of the wishbone. A bit of further reading and I came across using an Ice hockey Puck between the jack and car as acts a bit like a bearing. I picked one up via ebay and can only say its a brilliant suggestion. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #329438 26th May 2015 3:39am
^ Like the idea of an ice hockey puck Thumbs Up
Post #329445 26th May 2015 8:30am
They don't give you much - a couple of cm - but the material is good
I used to use one before I bought one of these
My kids play ice hockey so there's always a few pucks knocking around the house....
Post #329448 26th May 2015 9:02am
 2008 MY Supercharged
Post #329456 26th May 2015 10:38am
You should really get a bigger jack then, if it's tilting it's not up to the job...
better safe than sorry Thumbs Up Pete
Post #329458 26th May 2015 10:46am
ebajema
My two tonnes trolley jack, underneath the shock mounting point got the wheel well of the ground. But like Pete says, if the jack is doing funny things like tilting, something is wrong !!!! Wouldn't wanna think that it falls of while you are working on it, not even if you are not under it !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #329477 26th May 2015 2:23pm
ebajema
I bought two of the same adapters as Alistair. Work like a charm with the Sprinter and trolley jacks MY 2010 5.0 SC Galway green and sand interior!!
Post #329478 26th May 2015 2:25pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
You can whip off the plastic under tray and there is a flat section on the front cross member which is an approved jacking point.
There is also the same on the rear, but it's a &*@:"t because the exhaust pipes are in the way. For the front though it's pretty easy and gives bags of lift.
As echoed above I think if your jack is tilting, there is an issue that would give me the heebies about using it!
I upgraded to the jack on the right and it's a monster- was pretty cheap IIRC. (stupid jack on the left was a Hellfrauds one and it creaked etc- the reason it's looking quite second hand in the picture is that I lost my temper after it dumped my car and it became airborne)
Post #329487 26th May 2015 4:01pm
Zirconblue
I've got a couple of those small trolley jacks. They're ok for a normal car, but they're working at the very limit of their capacity on a range rover. They're handy for positioning heavy items though.
I bought a Weber trolley jack, http://www.pteonline.co.uk/shop/weber-stan...%29%7C250/ It's a dream to use compared to those cheap ones.
For a Range Rover you're far better off with one of those cheap 3 tonne jacks that everyone sells, but if you're buying a new jack for a 4x4 you may as well get a high lift one.
Post #329511 26th May 2015 7:34pm
