![]() | Home > Maintenance & Mods (L322) > Help - Can't jack car high enough |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Hi Guys,
Buy the Mercedes Sprinter hydraulic jack, plenty of stroke to get the wheels up |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8545 ![]() ![]() ![]() |
Put it under the front wishbone...
^ plus 1 on the location of the jacks under the wishbones, use to do that on my 2006 SC with the normal trolley jack until I got the Sprinter bottle jack for flat tyres (happened twice in Nigeria).
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
After reading this thread I tried to jack up my car via the wishbone. I lifted the car ok but the small trolley jack was just lifting off the ground on one side due to the angle of the wishbone. A bit of further reading and I came across using an Ice hockey Puck between the jack and car as acts a bit like a bearing. I picked one up via ebay and can only say its a brilliant suggestion. 2007 TDV8 VSE
^ Like the idea of an ice hockey puck |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
They don't give you much - a couple of cm - but the material is good
You should really get a bigger jack then, if it's tilting it's not up to the job... better safe than sorry ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
My two tonnes trolley jack, underneath the shock mounting point got the wheel well of the ground. But like Pete says, if the jack is doing funny things like tilting, something is wrong !!!! Wouldn't wanna think that it falls of while you are working on it, not even if you are not under it !!! MY 2010 5.0 SC Galway green and sand interior!!
I bought two of the same adapters as Alistair. Work like a charm with the Sprinter and trolley jacks MY 2010 5.0 SC Galway green and sand interior!!
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
You can whip off the plastic under tray and there is a flat section on the front cross member which is an approved jacking point.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I've got a couple of those small trolley jacks. They're ok for a normal car, but they're working at the very limit of their capacity on a range rover. They're handy for positioning heavy items though.
