![]() | Home > Maintenance & Mods (L322) > Front brake pipes corroded |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
MOT time again and this year, it's the turn of the brake pipes. Both front steel pipes are corroded. Whilst on the ramp, I had a look and they appear to have a join behind the plastic wheel arch trim.
Well on reading joe90s post, I can see that there is no join. The front pipes go up into the engine bay. Think I may have to invest in a flaring tool and a roll of pipe |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
I've all the gear to do my own pipes and completely redone a series III LR and other cars before but in your situation I would save the hassle and expense of making your own up and just buy the replacement pipes.
Where are the pipes online? Got a link? |
Have a look through microcat for your vehicle then just google the part number:
I've got a hand held on-car flaring tool. My plan was to cut the affected section of brake pipe behind the plastic wheel arch trim and fit a joint instead of replacing the whole run up to the block. The right hand side looks a pig to do running across the bulkhead. Much easier and quicker to fit a joint and run a short section of new pipe up to the flexible hoses |
Good luck with that ^^^^^
Having tried to unsuccessfully flare existing steel pipe for repairs then I would avoid the hassle!
I'm guessing they don't come pre-shaped and if they do, they'd be a |
I'll price the pipes up from that diagram as it may be quicker to change them. I didn't see that joint in the longer one, so that makes life a bit easier!
Assuming they are the same as BMW supply they won't come pre-shaped unless they can be installed with the shape set (usually just short runs).
£7.09 + vat for the two from Land Rover. In stock Thursday and the parts guy reckons they are pre-shaped 👍 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
They are pre shaped😬
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
If you can get them preshaped that would be the route to go,Anyone having their own go would look like a Dogs arse to the neat bends which anybody will see on any potential resale.It does not matter out of sight but would try to avoid putting in extra joins if all possible.I put copper to the rears on mine but there was a join in the wheelarch so didn't need to go up to the block! |
