Home > Maintenance & Mods (L322) > "stretched" Tow Ball Protection Plate
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Da da......
Post #328473 18th May 2015 5:26pm
Blimey... Shocked
Post #328522 18th May 2015 9:36pm
That's a few spacers Shocked
I could never figure out why the tow bar comes up that far short of the bumper
I used to have to do a similar thing with my bike rack, but I didn't like to have the tow hall mounted on so much packing.
Post #328523 18th May 2015 9:41pm
Zirconblue
Bringing it out further from the bumper reduces the amount of vertical load you can have on the tow ball. So i would imagine they've kept it close to keep the vertical load limit as high as possible.
Post #328554 19th May 2015 1:16am
mzplcg
Yep, I have the MaxRaxx as well but when I measured it from the centre line of the rear wheels the extra 36mm made a massive 2.97% difference so the maximum vertical load of 150KG (250KG if you reduce the max load in the boot by 100KG) was about 4 kilos. Since the caravan hitch and the one on the Ifor Williams are max rated at 100KG it doesn't matter.
@Cliff. Add another inch or two mate. You'll protect the back window as well then Laughing
Post #328561 19th May 2015 8:06am
devonchilliman
Cam-Tech-Craig wrote:
Blimey... Shocked
Rolling with laughter tis for a very good reason Wink ...unlike you chaps with tin tents ,I very rarely park on nice flat level ground when I have the trailer on,so as you unhitched & level up the trailer the drawbar ends up as high as or even higher than the bumper and more often than not the drawbar extends out towards the FF,so it's only a matter of time before the bumper is Censored ...I know i look stupid Whistle
Oh and only one spacer used Thumbs Up
@dom Rolling with laughter Ner Ner
Post #328575 19th May 2015 9:43am
Cliff, did you just accuse me of owning a tin tent sir Confused Confused Confused
Post #328577 19th May 2015 9:46am
devonchilliman
Would I ever...just the likes of Dom Whistle
Post #328578 19th May 2015 9:56am
Like ide get the time to use it Shocked
Laughing Laughing Laughing Bow down
Post #328579 19th May 2015 9:57am
devonchilliman
Off Topic Garry was asking if I have the actual speed displayed in numbers on my dash and if I don't it's an enablement that you can do,is this so? Thumbs Up
Post #328580 19th May 2015 9:59am
mzplcg
Hey, now then.....I've got an Ifor as well Ner Ner
Post #328582 19th May 2015 10:03am
devonchilliman
Wink
Post #328583 19th May 2015 10:05am
It "tis" yes sir... Thumbs Up
Post #328584 19th May 2015 10:21am
devonchilliman
So that's 3 reasons to visit you now Whistle
Post #328725 20th May 2015 9:20am
Indeed... (but i forgot the other two) Embarassed Embarassed Embarassed
Post #328727 20th May 2015 9:24am
